Old 08-23-2003, 09:08 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Looking for info on Tranny/Clutch Replacement
I was going to attempt to take out my tranny, clutch and axles. Where can I go to find out step by step how to do all this? Thanks guys.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 08-23-2003, 09:36 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
I think that the only place to get a step by step description of doing your clutch is in a manual like Chilton's or Haynes. However, it's a simple enough job, that you should be able to do it yourself. The main steps are:
Pull battery
Pull intake
Disconnect clutch cable
Pull starter
Drain trans oil
Remove wheels, disconnect lower ball joint, remove large hub nut
Disconnect axles from trans
Support Trans with jack and disconnect 3 trans mounts
Remove all bolts from around trans and inspection plate
Remove clutch
Then reverse. You'll want a manual for torque specs, or if you need, email me and I'll get them out of mine.
You'll want to make sure before you get to it, that you have a twelve-sided 10mm and 17mm socket. you'll need them for the clutch parts. Your new clutch should include some instructions on mounting the clutch to the flywheel. You'll also probably want to get your flywheel turned, to have a nice clean surface. If you run into any problems, just post up and you're sure to get some help!
Good luck!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
