Old 08-23-2003, 07:13 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
could it be the starter?
hey everyone.. my civic starts weird sometimes. its hard to start with a warm engine. like i would go 10 miles from home to downtown, turn off the car for a quick stop at 7 eleven and it would have a hard time starting from there. there are like no problems when the motor is cool or off for like a few hours. i turn the key and the starter wouldn't start. then i rest a while and turn the key again and the start would turn the engine but it wouldnt start. the check engine light comes on comes on after this. then after a few more tries it starts, the check engine light dissappears. what could be wrong? all wires are attached. ground and everything. my dad cleaned the starter a while ago and it was fine. do i need a new starter?
Old 08-23-2003, 07:36 PM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
it could be a number of things next time it throws the check engine light leave the key on and check the computer. if you dont know where its at its located under the carpet in the passengers side where your feet would be. so pull the carpet up and your computer will be right there. there will be a red light flashing on and off. now pay attention to the flashes there two types of flashes, one is a quick flashe(on and off) and the other is a little longer flash(red light stays on a little longer then goes off) the long flashes count as ten and quick ones count as one.example if there is a long flash and then three quick onesthat will be code 13. if its two long flashes back to back and 5 quicks ones after thats a code 25. i dont know if im making sense this is my first post in months letstry it this way
1= long flash(10)
2=short flash(1)
112222222- that would be code 27
12222- that would be code14
11- code 20
112-code 21
ok im not goodwithexplaing but maybe that will help u read the code. do that then come back and post what code it throws. make sure its throwing the same code twice back to back cause it could be throwing more than one code. let us know then we can go from there.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 08-23-2003, 07:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
forget all that, its your Main Relay, behind the hood pop thingy, about 40bux from the dealer, notorious for going bad, and for giving the problems you described.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-23-2003, 11:17 PM
bionictony's Avatar
it threw out a code 16... check the fuel injection system...
i found this online:
Code 16 - Fuel Injector
Code 16 is probably the Main Relay, however it could still mean a bad Injector, Resistor Box tho.
Most failures occur, when the weather starts heating-up for the summer...
If the car refuses to start, but "turns over" on a hot day, try opening the doors/windows, and let the interior cool down. "Then try starting again". May not work all the time, but worth a try anyway. Also, would help in troubleshooting the prob, if it does start. Another place to look is the ECT sensor, refer to the above
thanks for the help
Old 08-23-2003, 11:21 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
IM GETTING THE SAME PROBLEM.......Ive been thinking bad injector.....or Main Relay.....Im going to replace my main relay now........I've been getting SOOOOO Pissed.
89 DX: LS Powered
88 CX: Project ZC
Old 08-24-2003, 12:40 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: could it be the starter?
http://www.fourthgenhatch.com/mainrelay.html
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-07-2005, 12:19 PM
contrerasl contrerasl is offline
Starting Problem
This Morning I Tried To Start My Car And The Starter Would Not Turn. I Know The Starter Is Not The Problem Because It Is New. Sometimes The Starter Turns And Makes A Loud Screaching Noise. That Noise Is Exacly The Same To When A Car Is Turned On And You Turn The Key To Turn The Car On. What Can Be The Problem To This?
Old 07-07-2005, 12:40 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
must be everyone...mine wouldn't turn over either...not dizzy, so on to the main relay
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
