Old 08-23-2003, 05:10 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
crank pulley
how do u get the crank pulley off a first gen b16. please respond!!!!!!!!!
Old 08-23-2003, 05:18 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: crank pulley
Loosen the Bolt in the middle of it
Seriously though, they are always really hard to get off. Do you have an air hammer? If you do, try that or a breaker bar. You can try using chemicals like liquid wrench to help you out a bit. Just keep trying, its a bitch but its gotta be done.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-23-2003, 05:28 PM
Re: Re: crank pulley
yeah i cant get the pullys to stay so it doesnt spin..........its really fu**ing annoying
im trying to change the timing belt and water pump but i have to take this shit off to change it.........
Old 08-23-2003, 05:43 PM
Re: Re: Re: crank pulley
If you have the flywheel off, put atleast 2 of the six bolts back in on opposite sides. Stick a metal bar in there or something so that one end is wedged between the 2 bolts and the other end is against the ground. Then go ahead and try to loosen the pulley bolt. You know what im saying?
ZC stuff
Old 08-23-2003, 06:52 PM
HONDABOND HONDABOND is offline
I have had to do this a million times. The best way is to have a pal hold the crank pully, take off the drivers side wheel and there is a small hole were you can put a wrench throught. Get and extension and a breaker bar and go at it. This should only take one rotation.
Also there is a special tool to hole the pully without maring it.
White folk eat noodles too.
Old 08-23-2003, 06:59 PM
91civicDXdude's Avatar
nobody ever takes my advice on this, but it is a foolproof way to take the crank pulley off and works like a charm.
BTW, this is to counteract the "stick a wrench in the crank pulley to keep it from turning" point of view, becuause i've seen about 4 honda crank pulleys bust from doing this.
Okay, what i do is get a length of nylon rope. Clothesline rope works very good. Next, put the engine at #1 cylinder BDC, or close. Then, you want to take out the #1 spark plug. Now this is the part everybody scrutinizes me over, but what you will do is take the nylon rope and feed it through the spark plug hole and fill the entire cylinder up with rope. it will take a couple feet as the rope is soft and will smash. fill the cylinder all the way up with as much nylon rope as you can fit. then, just turn the crank pulley. the rope will compress and distribute even pressure against the piston, effectively making the engine not turn.
I've done this on 2 or 3 hondas with no problems, and it is an old V8 trick used to mechanics for years with no problems.
Old 08-23-2003, 07:12 PM
Ive never heard that before, its really creative. Next time I need to change a timing belt, water pump, or whatever, im gonna try that one.
ZC stuff
Old 08-23-2003, 07:19 PM
I would rather break and replace the pully.
BTW, I hope you are using a REAL Harmonic Balancer.
If you are stupid enough to use a solid crank pully, your engine is shot anyway.
Old 08-23-2003, 08:03 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
If you dont have air tools, you can rent electric impacts that will spin the center bolt off easily. The initial impact of an impact gun can quite often break the bolt loose without spinning the crank. Electric impacts can be quite torquey and they dont require a compressor, they usually cost something like 30$ a day to rent. If that doesnt work, take one of these guys ideas (although Im not so sure about the rope idea). Also, even after the center bolt is off, the pulley may be stuck and you may need a three jaw to remove it.
Beer tastes better upside down.
Old 08-23-2003, 09:08 PM
i got it i took the oil pan off and to do that i had to take off this cover like right behind the tranny and it was covering the flywheel so i stuck a flathead screwdriver in it and just to came off it took like 5 trys i was try9ing all day with all these other idea but nothing worked ........... until i read the haynes book haha....but it turns out i got the wrong timing belt so i couldnt finish it i jsut have to put that on and run a couple wires and i can drop the bitch in i cant wait.....
Old 08-23-2003, 09:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
next time go with 600ft/lbs of torque in a nice impact wrench, came right off for me
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-24-2003, 06:21 AM
ian16v ian16v is offline
i was gonna change my timing belt yesterday and came across the same problem!! i was trying for ages with an air gun, still didnt come off, i was raging!! one o the other mechanics gave me a hand to lock the pulley and hold it while i put a big pole over a breaker bar and hung on it!! still didnt bloody come off!
mite try that rope idea, sounds like it could be a winner
1995 Toyota Starlet GT Turbo Advance & 1991 civic b16a1 project/track car
http://www.boomspeed.com/civic16v
Old 08-24-2003, 09:42 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Be careful about putting too much awkward force onto the crank bolt. My friend snapped his bolt in half with the threaded part still inside. Good luck ever getting that out.
The hands down best way is an Impact Wrench. My 600ft-lb Craftsman took off the crank bolt in less than a second.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-24-2003, 01:51 PM
SiZ's Avatar
SiZ SiZ is offline
Re: crank pulley
1st gen B16s have a solid crank pulley anyway.
"The nympho of info, I'm fuckin' what ya heard"
Old 08-24-2003, 08:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if u cant get it off with an impact, put more oil in the gun and turn up that compressor.
my impact suppose to run at 90psi but like when i had to take off my crank pulley and head bolts, i had that thing up to 120.
Team Lonely Drivers
