Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 08-23-2003, 12:42 PM
cstyle13 cstyle13 is offline
Unhappy Dual halo projector headlights help
I have a 97 accord. I recieved my projector headlights. But i have a problem with the wiring. There are extra pos and neg wires along with the factory light clip. Where do i hook theres wires up too.
Old 08-23-2003, 01:36 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Your turn signal wires. I know on my Civic there are three going to the signal bulb and it will most likely be the same on yours, or any car. One red (pos) one black (neg) and one green or some other color (for the blinking signal) but leave that one alone. You can either solder it or do a ghetto-tastic wire twisting job...
Old 08-23-2003, 01:47 PM
i hooked the positives in with the proper factory light clips(the ones you snap the lights into) and the low beams come one but when i go to flip it to high beam the high beam dont light up
Old 08-23-2003, 01:59 PM
Ricochet's Avatar
Banned
Re: Dual halo projector headlights help
So you plugged the halo lights into the regular light plug? That will suck the power away from them... Just wire the halos into your turn signals because I grounded my foglights at the same ground my headlights were, and the headlights were 1/2 as bright.
Can you take some pictures?
Old 08-23-2003, 02:23 PM
if i plug them into my turn signals wont they come on only when i use my turn signals?
Old 08-23-2003, 02:41 PM
Ricochet's Avatar
Banned
Didn't you read my post above?
The third wire sends the signal for the bulb to blink, while the red/black wires are for power only. When your parking lights are on your halos will be on also. When you flip your signal on, the halos are still using the power from your parking lights and only the turn signal bulb blinks.
Old 08-23-2003, 02:43 PM
Having problem getting my high beam to come on.
Old 08-23-2003, 02:49 PM
Ricochet's Avatar
Banned
Hmmm sure it's not the bulb?
Old 08-23-2003, 03:01 PM
hooking into the turn signal didnt work. the lights blinked with the turn signal. i dont want to hook them up to the parking lights. any other suggestions?
Old 08-23-2003, 03:04 PM
Ricochet's Avatar
Banned
Your wiring must be different from mine, sorry about that. You could always take them straight to the battery with an inline switch... I don't know what else to suggest.
Old 08-23-2003, 03:13 PM
hey thanks for all your help man
dual halo projector headlight problem NotAlwayzEvil '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 01-08-2006 09:15 PM
88-89 Dual Halo Projectors on a 91? tojomagic '88 - '91 Civic | CRX | Wagon | Shuttlee 7 01-20-2005 02:33 PM
Halo projector headlights for the Alero bubbabubba Alero 0 10-29-2004 04:27 PM
1998 Dual Halo Projector Installation Rangers_86 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 18 02-06-2004 10:38 PM
2000 Honda Accord Double Halo Projector Headlights Installation Help scimitar4701 Accord/TSX/Accord Hybrid 2 11-07-2003 10:44 PM
