Old 08-23-2003, 05:49 AM
substance's Avatar
substance substance is offline
Send a message via AIM to substance
2000 Civic EX Swap!?
For some reason or another the engine on my 2000 Civic EX went out so I'm going to have to get a new one (pronto). I was looking into getting a bigger better engine since i'm going to be needing a new one anyway, thats where i came accros this "engine swapping". From the looks of it, the b16 will prob be the easiest/cheapest choice. If i decide to get this i have a couple questions:
1.Where do i locate/buy this engine from? Do i get it new or used?
2.If i do get this engine, will i have to update any of my other components?
3. Will my old mods work with my new engine? (CAI/headers)
4. How much does it run all together? (buying, putting together)
5. Turbocharging? I've herd if you do this it will lower the life expectancy(sp?) on your car. Oh and does turbocharging give it that little "pssst" noise? or is that supercharging?
Also i plan on getting a new exaust in the near future so is there a brand highly recommended for the new engine?
Any suggestion will be appreciated ;]
Old 08-23-2003, 06:54 PM
96HondaCivic 96HondaCivic is offline
Anything you do to upgrade your engine (i.e air intake, headers etc.) will lower the life limit on the engine. And as far as the "psst" sound, i know that turbochargers give off that sound everytime you switch gears with the help of a blow off valve, just not sure about superchargers.
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Old 08-23-2003, 06:57 PM
1. www.osakajdmmotors.com
www.hmotorsonline.com
www.inlinefour.com
2. Probably the Motor Mounts and the harnesses.
3. No 'D' series engine mods work with a 'B' series engine.
4. The engine and installation will run around 3k probably, depending on the installation cost.
Old 08-23-2003, 08:48 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: 2000 Civic EX Swap!?
1. www.hmotorsonline.com used
2. most likely motor mounts, although im not sure if you will need them as the b16 was available in that year civic. when swapping you should replace; timing belt, water pump, plugs, wires, and distributor cap and rotor.
3. no your headers will not swap, however an intake may or may not fit, just slap it in and see, but be in the idea that most aftermarket parts will need to be re-bought.
4. engine and shipping from hmotors cost me 1500 to NY, not sure where you are from, install is around 1000 in NY as well, call local shops for an estimate.
5. turbo and supercharging both will lower the life span of your engine if not mainted/installed right, they both also make the psst sound.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
