Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-23-2003, 12:50 AM
sideshowrich's Avatar
sideshowrich sideshowrich is offline
2 people short of a 3way
Send a message via AIM to sideshowrich Send a message via MSN to sideshowrich
Drum to disc conversion
I have a 99 civic DX coupe, and I was looking to do a rear drum to disc brake conversion. Could anyone help me out with this, what parts would I need to get besides calipers and rotors, and from what cars. Also, would I have to get the rear calipers from disc brake equipped car, or would the front calipers from another civic work?
One last question: if I wanted to do a five lug Type R conversion along with the brake conversion, which parts would I need for that?
Any help with this would be greatly appreciated, thanks!
Old 08-25-2003, 09:33 AM
Anyone????
Old 08-26-2003, 10:16 PM
FrankenCivic FrankenCivic is offline
Lightbulb Re: Drum to disc conversion
Originally Posted by sideshowrich
Anyone????
Hey bro,
I am working on the same deal. Here is what I have amassed (and from where) so far:
1995 GSR Rear End:
Rear trailing arm with hub assembly for disk brakes (Ebay or junkyard, whichever is easiest to find)
Upper control arm (Ebay or junkyard, whichever is easiest to find)Compensator arms (at the front end of trailing arm) (Ebay or junkyard, whichever is easiest to find)
Rotors (Brembo)
Brake calipers and brackets (Ebay or junkyard, whichever is easiest to find)
Brake pads with shims (get the genuine Honda ones)
Parking brake cables (new and OEM, got one from A&H motorsport {ahmotor.com} and one from Rock Auto {rockauto.com}. A&H will probably have both, but Rock had one for a bit cheaper.)
Brake Lines (rockauto.com)
Various clips, pins, bolts, etc. (call A&H, they've got it all for cheaper than most everywhere. Match their prices against your local junkyards and your Acura dealer)
What I am missing:
1998 LS Master cylinder, brake booster and proportioning valve. the LS is important because it is the only one that doesn't come with ABS. Some minor modification is needed to bolt this in, but with some patience, a flaring tool, and some elbow grease, it all goes together. That is what I have heard anyway. I haven't done it yet myself, but we'll see.
Let me know how this works for you.
-Mike
Old 09-03-2003, 09:05 PM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
Hay Bro,
Check out any of these sites they have what your looking for....
www.Passwordjdm.com
www.jdm.com
www.jdmcivic.com
www.jdmparts.com
www.jdmhondaparts.com
Look around there and see if you can find a good price.....The last time I looked I found a 5 lug conversion for about $1200 thats all you need to change your rear brakes to disc and going 5 lug....
2001 ITR
WWW.SQUADONE.NET
Old 11-02-2005, 10:13 AM
blkcivsi blkcivsi is offline
i have the complete rear disc conversion from a 95 gsr which will bolt right on your car. it comes complete with all the components the other guy said you needed. even the discs and calibers. if your interested email me at [email protected] or call 610-737-4681
