| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Give me your thoughts. What is the best engine and tranny swap built for high boost to put into an Accord body that would give it great torque and a higher top speed?
Just becuase of the sole reason that it is an accord, i would go with an h22a. You better plan on cracking it open and building it up first though, if you plan on boosting high. The h22a has a bad history of weak internal components.
What would be the best tranny to put in it.
well your limited to whatever motor you have, if you an F22, then you can only use a f-series tranny, or if you go h22, then you can only use an h-series tranny, you cant mix and match them.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Well if thats the case, which tranny would be the best choice for a boost setup good acceleration and good top end. The H22 or the H23.
as far as i know the trannies for the h22/23 were the same, all you could do would be to add LSD to it, and maybe change the gear ratios.
k thanksfor the help.
