Old 08-22-2003, 04:45 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
6-bolt and 7-bolt
i dont know much about these cars yet and i would like to find out what the difference is between a 6-bolt engine and a 7-bolt? i am not sure where they made the change at? thanks.
Old 08-22-2003, 06:42 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
6 bolt has a greatl less chance of gettin crank walk but the seven bolt has a grater chance of getting crankwalk...
the 6 bolt is found on 90-94 dsm.. i think..
and the 7 bolt is found on the 95+dsm..
1
Shift_BOOST
97 s14
Old 08-22-2003, 07:27 PM
timex timex is offline
i believe the 6 bolt is actually 90-92.5, then 7-bolt is from then on
they changed to the 7-bolt in may or june of production in 1992
The difference between insanity and genius is measured only by success.
Old 08-22-2003, 08:52 PM
2of9 2of9 is offline
when u guys say 6-bolt and 7-bolt, wut does that mean in a DSM engine. cuz i hear it alot, is it part of the inside engine or wut? im not too good at DSM engines.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 08-22-2003, 09:28 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
It refers to the number of bolts holding the flywheel to the crankshaft. And yes it was late 92 that they made the change.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 08-22-2003, 09:41 PM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Re: 6-bolt and 7-bolt
Specifically , April-May of 92. Every 1G after that , T and NT , had a 7-bolt motor. '95+ was when they started using the 420A for NT cars. This all information that can be accessed thru any local DSM club , or dsm.org. Its been talked about extensively here ,so I would suggest searching for something first.
This place is getting more like "Toonerz" everyday.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-23-2003, 12:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
I'm all toonered out... I'm a wiseman there, and I havent been there in weeks, lol. I believe the actual change was closer to july of 92. Most automakers retool over the July 4th shutdown (the only time they ever shut down typically). Either way, when they retool in the summer is when they are actually making the NEXT years cars. So the change was intended for the 93 model year. In fact, I have nly ever heard of one 7 bolt 92. And it was a July car if I recall. But always check. See the vfaq for how to tell easily by looking at the oil pan...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-23-2003, 01:00 AM
95_GSX's Avatar
thanks for the info.
Old 08-23-2003, 09:45 AM
do u DSMers change the flywheel and the crankshaft to 6-bolt instead of 7 bolt on the 93+ DSMs? im pretty sure people have, but i dont kno about this problem yet. i want to kno how to fix it when i get a DSM. Will it be hard fixing the 7-bolt to a 6-bolt?
--2OF9--
#808/1000
Old 08-23-2003, 10:57 AM
AF - Advisor
You need the whole block. They chnaged that as well, and the rods. The most common budget build up consists of the 6 bolt block, crank, "big" rods, and 2g pistons. Thats the best mix of the stock parts, but the rods need the small end narrowed to fit the 2g pistons. There is a vfaq with the dimensions the machine shop will need to make it happen. MANY people do the conversion to the 6 bolt motors. I've done a couple in 2Gs myself.
Kevin Jewer
Old 08-23-2003, 03:44 PM
95_GSX's Avatar
is it a pretty up front swap? like pull ur 7-bolt swap your parts to a 6-bolt and drop it in? and where is a good place to find 6-bolt engines?
Old 08-24-2003, 12:50 AM
AF - Advisor
If you are refering to putting a 6 bolt in the 2g cars, see www.magnusmotorsports.com, tech articles, 1gina2g. When I did my first swap, I found that all the info I needed was right there. RRE has a good page on how to set up the 1g CAS as well. Its a good deal of work, but if you're comfortable doing head gasket swaps, or timing belt jobs, then it should be doable.
Kevin Jewer
Old 08-24-2003, 01:01 PM
95_GSX's Avatar
looks good, thanks for the help.
