Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 08-22-2003, 04:38 PM
DarkAccord600 DarkAccord600 is offline
Send a message via AIM to DarkAccord600
handling problems
I need some help here. When I make sharp turns in my car my back tires want to bounce alot. I have kyb agx shocks and skunk 2 coilovers what can I do to prevent the back half of my car from bouncing as much.
Old 08-22-2003, 11:23 PM
aCordiaN aCordiaN is offline
Send a message via Yahoo to aCordiaN
Same problem here, would like some info & help on this please.
Thanx,
{"peace"}
{~aj~}
Old 08-22-2003, 11:41 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Do you mean like bounce like you just went over a bump? If thats the case, then its just that your coilovers are bouncy, skunk2s are good quality, but coilover sleeves in general are VERY bouncy.
Old 08-22-2003, 11:58 PM
Well 4 me, it's like when im going on a curve something like a " S " but not a very narrow thing, very simple. My car's rear just misses it's tracktion. Seems like a rally kind of a thing.
A few dayz ago i was like taking a long curve turn, n i used my brakes, the car just seemed 2 go straight while the wheels were turned 2 the left. I took my foot of the brake and the car just went out of controll, like going i didn't have a steering.
Thanx.
{"peace"}
{~aj~}
Old 08-23-2003, 12:22 AM
99civic03's Avatar
Hmm I dont know what to tell you sorry.
Old 08-23-2003, 02:13 AM
BullShifter's Avatar
First off the only pedal you should be touching in a corner is the gas pedal. Brake/downshift before entering the corner. When you were turning the wheels left & going straight - thats understeer.
Darkaccord - check your tire pressures & loosen up the rear end a bit or maybe tighten depending how you have it set now. Rear wheel hop?
Old 08-23-2003, 09:36 AM
Yeah I was thinking maybe of tightening up a bit. Maybe putting a good sway bar would help. I know its to help roll but what about keeping the tires on the ground.
Old 08-23-2003, 07:42 PM
Sway bars tie both ends of the suspension together making an independent suspension less independent. Rear sway bar upgrade will definatley help your handling issues.
Basically in a turn the body leans - taking weight off one side. A sway bar should add more weight/force to the opposite side.
Old 08-23-2003, 11:32 PM
Thats exactly what I was thinkin about. Thanks.
