Old 08-22-2003, 03:00 PM
hybridnorthern hybridnorthern is offline
custom headlight buzzer
I want to wire in a headlight buzzer. I found this page http://www.torontocivics.com/article...er/buzzer.html
,but I dont want to just jam wire into the fuse slots. Does anyone know a way to solder the buzzer in? (spelling???)
Old 08-22-2003, 03:27 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
i have no idea about soldering, but why not just put them into the fuse slots? thats what i did and i've had no problems at all.
only thing, when the car is off and i press the brake pedal, i can faintly here the buzzer, why is that?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 08-22-2003, 04:02 PM
I dont want it to fall out (could happen) and I would like something more permanent. I dont know why it would buzz when you have your brake pressed. I will try it and see if mine does the same thing.
Old 08-22-2003, 06:25 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
What's wrong with the factory one?
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-22-2003, 06:36 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Re: custom headlight buzzer
usdm civics dont have headlight buzzers
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-22-2003, 07:41 PM
Jay eS Iye's Avatar
it won't fall out b/c it has the fuses holding it in. and if it does, just put it back in i just think it'll be easier this way
Old 08-22-2003, 08:51 PM
BullShifter's Avatar
I dont know the technical name for the part, but its like a piggy-back connector that you install in the fuse socket, then install the fuse in the connector. On the connecter is a spot for a blade connector for you wiring, they come with single post or dual.
Jamming a wire with a fuse in the same socket is a bad idea When all you need a simple $.10 part.
