What's vtec for anyway?
Alrighty, i'm just asking a serious question here so elighten me. I've never known what honda came up with vtec for so i'd like to know what is it's purpose? high rpm valvetrain stability? gas mileage? Just curious cause there's a lot of talk about, "vtec this" and "vtec that". (putting my flame suit on
1990 Mustang GT. |
VTEC = Variable Valve Timing and lift Electronic Control.
What it does is when a car hits vtec usually at about 5500 rpms or so it in away switches to using different lobes on the camshaft, making the duration and lift on the valves greater, increasing the amount of air you can put into each cylinder and their for increasing horsepower, in the top end. Thats the basic of how vtec works and what it does.
Its not how fast you go it how fast you finish. Second place is the first looser Skunk2 Coil-overs Aem 2 piece intake Tanabe Exausht Throttle Body coolant bypass Apexi SAFC 2. Skunk 2 cam gear. ZEX dry nitrous system: currently 55 shot. Best 1/4 Time: 16.402 @ 82 M.P.H w/ 2.290 60ft w/o spray 14.8@94 MPH w/ spray |
Re: What's vtec for anyway?
-Andrew-
ON the D series engine where you only have one cam there are a set of lobes that only open up for the intake side.
But in reality VTEC, VANOS (BMW), VVTL-i (Toyota), and other companies that have this feature you get the best of both worlds. Great fuel economy, and a little bit more power at the high end. That's why all these cars can rev so high. Notice the Hondas, Acuras, BMWs, and Toyotas all rev up past 7000-8000rpms.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!Autocross Help Page Buy my Civic parts! |
Then there's the VTEC-E ("E" for economy). This is what I have in my 92 Civic VX.
I'm not a motor head by any stretch of the imagination, however, after some web surfing I've found that the Honda Civic with VTEC was first introduced in 1992 (USA & Canada). From what I've found, there are two different VTEC engines. The VTEC(D16Z6) and VTEC-E(D15Z1). The VTEC is equipped with multiple cam lobes per cylinder, providing one valve timing and valve lift profile at low speeds and a different profile at higher speeds. Switch-over from one profile to the other is controlled electronically, and is selected by monitoring current engine speed and load. Unlike the typical VTEC whereby it kicks in at 5500 rpm's as suggested by Options, the VTEC-E kicks in at ~2000 to 2500 rpm's (it even has a gear shift indicator to assist in optimizing fuel efficiency). Hope this helps. Knowledge is key, Jesus is King. |
Re: Re: What's vtec for anyway?
Ok, so how then with an SOHC does it benifit to allow more air in, but no more out? I would think that would create problems.
Even if the exhaust valves are at capacity when it is at normal conditions, when vtec were to kick bernoulli's principle would take into effect, pushing the extra exhaust gas produced during the combustion cycle out.
Since VTEC is really creating two powerbands (one for each lobe), doesn't it increase low-end and high-end power? Isn't it like having an engine optimized for both low and high speed?
2003 Civic EX 4D D17A2 (Stock) 5-Speed Manual |
so, what's the difference between regular vtec and i-vtec (like in the '03 civic si)?
I have no idea my self i have heard its like a 3 stage vtec or something i really have no idea.
