Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 08-21-2003, 10:44 PM   #1
ikoiko79
Newbie Xterra owner
Hey all. I just bought a 2001 Xterra XE last weekend and am still learning about everything I can do with it. Are there any maintenance issues I should know about? I have about 3,000 miles left on the bumper to bumper, and would like to get everything checked out that should. I also noticed today that when I go in reverse down the curb on my driveway it sqeaks loudly. What could this be? Or is it normal?
ikoiko79 is offline   Reply With Quote
Old 08-22-2003, 12:14 AM   #2
Schludwiller
XTerra Guy
Schludwiller's Avatar
Re: Newbie Xterra owner
If it comes from the front while you're turning at full lock it 's probably your steering stops. The plastic covers wear quickly. Some grease takes care of that.
As far as I know, unless something is wrong you'll get charged for having them "check" things.
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 08-22-2003, 12:34 AM   #3
ChuckH
ChuckH's Avatar
Yep, they will charge you about $75 to check things unless a problem is actually found. The only big thing I can think of that might be worth having checked is the exhaust manifolds; especially the passenger side, but you have until 5 years or 60K on drivetrain and having them checked is no guarranty that the dealer does it or is competent enough to tell when one is cracked.
The only other issue that seems to only apply to 2001's is a power window problem. Apparently Nissan went to a plastic clip in the window regulators (this is what I've heard anyway) and some people have had problems with them breaking. Problem is, this isn't something you can have the dealer check; the windows either work or they don't.
ChuckH
ChuckH is offline   Reply With Quote
Old 08-22-2003, 09:36 AM   #4
ikoiko79
Thanks a lot for the help. Yes, it only happes when the wheel is turned the fartherst it can go and while in reverse. Where are the steering stops so I can grease them?
Thanks again for all your help
Old 08-22-2003, 09:53 AM   #5
OffroadX
Send a message via AIM to OffroadX
Steering stop info: http://pub175.ezboard.com/ftunfsfrm2...picID=39.topic
Pics are missing in that link. Here's one for reference
The steering stop is just visible about 1/3 of the way up to the far right, and the dark vertical streak about 1/3 of the way from the right side directly across from it is where it rubs on the control arm. Apply grease to both points and it will get quiet. There are a total of 4 stops, one the front and one on the rear of the control arm, and the same pair on the other side's control arm too.
Brent
OffroadX is offline   Reply With Quote
