Old 08-21-2003, 08:24 PM
RiPSTeR RiPSTeR is offline
Unhappy Please Help!!!
My car is a 1992 LeSabre. I'm not exactly sure what the specific hose is called, but may be Thermostat Bypass hose, or maybe just Bypass Hose. It's mounted on the top of the water pump and screws (via a plastic attachment) into the block. The only thing I'm 100% on is that it is a water hose.
Anyway, the plastic screw-in attachment broke off flush with the block, so now I have melted plastic in aluminum threads. I'm prepared to re-tap the threads if necessary. Hopefully there's an easier way to remove the melted plastic.
My worst problem though, is that I'm having trouble replacing the melted piece because I don't know exactly what it's called.
Has anyone encountered this melted plastic problem? What should I try?
What's the attachment called?
Thanks.
Old 08-21-2003, 09:17 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Bypass nipple
If you can locate an easy- out large enough to fit in the hole, the broken off piece will screw right out.
Otherwise you can take a hacksaw blade and cut the plastic and break off the pieces.
GM parts has a metal replacement available.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-22-2003, 07:35 AM
Thank you GMMerlin!
