Old 08-21-2003, 05:31 PM
blade34609's Avatar
blade34609 blade34609 is offline
Tie Rod
Hi,
I just realized I have to replace the balljoint in the right side outer tie rod end.
But none of the part stores carry just the balljoint only upper and lower ones.
So I have to buy the Tie-Rod all together.
I think its about 30-40 bucks all together.
Does the outer tie-rod just unscrew from the steering?
I think your supposed to have 2 wrenches and turn then mark it so I dont forget the alignment.
Anyone every replace theirs?
THanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-22-2003, 02:51 AM
BullShifter's Avatar
Tie rod replacement is pretty simple. If you havent had an alignment recently then after replacing the tie rod is a good time - tie rods control toe. You can scribe a mark on the threads or count the # of turns.
Lift & support front end or entire vechile(recommended - less chance to roll off the stands)
Remove wheel/tire
Remove cotter pin
Loosen castle nut to the end of threads(flush)
Then beat it loose with a Ford wrench(hammer) or seperater.
Remove alxe nut completely
Un-bend lock washers
22mm wrench hold rack - 17mm remove tie rod
Reverse for install - Dont forget the cotter pin & bending the lock washer back.
Old 08-22-2003, 11:10 AM
blade34609's Avatar
Ok,
When i buy the tie rod it will come with the balljoint correct?
Im pretty sure cause thats what the guy said at Autzone.
Its the one that has the cotter pin and turn the wheels.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-22-2003, 11:52 AM
The ball joint & tire rod come as one piece.
Old 08-22-2003, 12:27 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Im just gonna back up what jackassi has said, it is pretty easy.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-22-2003, 01:24 PM
blade34609's Avatar
Alright thanks guys.
I just came back from Discount Auto and it costs me 48.80 for the passenger side outer tie rod.
But i guess its worth it considering my current ones balljoint is fallin apart (all the rubber is torn off).
They said i should get it "hopefully" tommorow afternoon.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
