Old 08-21-2003, 05:42 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
4th gen question for all(headlight switch related)
This stumps me..I have noticed that on my friends 90 civic hatchback DX and 90-91 4 door LX....when you pull back the headlight switch(for brights) when the car is OFF(no key in ignition), they turn ON, just the brights. I was wondering why MY car doesnt do this..Mine is a 91 Si and I thought its somthing it should have. Or maybe Si's were not meant to have this option.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-21-2003, 05:56 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
they broke the bank on the sunroof ... so they had to eliminate it
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-22-2003, 12:14 AM
umm what? the bank?..youre wierd melt TTT
-2000 Civic Hatch
-1998 Lexus SC300
Old 08-22-2003, 12:15 AM
Melt's Avatar
Re: 4th gen question for all(headlight switch related)
what i was tryin to say is because of the sunroof and mpfi they emilinated the headlight option ... maybe ... i dont have any actual evidence to back up my theory
AF Bay Area Crew
Old 08-22-2003, 12:33 AM
EFStali's Avatar
EFStali EFStali is offline
Send a message via AIM to EFStali Send a message via Yahoo to EFStali
uh i dont understand it..when i do my high beams with no key in..they dont turn on...
Name is Adam
Old 08-22-2003, 12:34 AM
Melt's Avatar
your guyses cars all suck then!
AF Bay Area Crew
Old 08-22-2003, 12:36 AM
EFStali's Avatar
i have the same car as you dumb nut ha ha ha just playin
Name is Adam
Old 08-22-2003, 12:39 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
rene you are a weired cat
but yea, not sure my friend doesnt even have bright on his 89 4 door
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 08-22-2003, 12:41 AM
Melt's Avatar
which is why im suprised it doesnt have it .
AF Bay Area Crew
Old 08-22-2003, 02:44 AM
GTA's Avatar
GTA GTA is offline
Whee..
mine flash without the key in if i pull it.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-22-2003, 04:00 AM
BullShifter's Avatar
The high beams can flash with the key off on my 91 Si
Old 08-22-2003, 03:16 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
headlight stalk
There is something in your headlight stalk that is broken...Mine used to flash, and then one day it just stopped...it still turned the high beams off and on with the headlights on, but it didn't flash just the brights the rest of the time. I replaced my stalk with one from another car at the junkyard and solved the problem. I also had to replace my wiper stalk, because the spring that holds it up and pulls it back from the "mist" option bought the farm and it hung down and randomly fired the wipers off. - So I replaced that too...I found about 3 others in the junkyard with the same issue so I guess it is a common problem.
It takes about 10 minutes to pull them out and replace them.
1. Remove steering wheel and column trim
2. remove 3 or 4 or 5 phillips screws holding stalk in column
3. slide out stalk, remove wires.
reverse procedure to install..
I think I paid $10 for both stalks at my junkyard, so they are pretty cheap.
However, there is a difference between the 88-89 & 90-91 stalks (of course...every damn thing else is different ) - The ground wire tab is in a different spot and won't install correctly, so for true plug & play get the same year/trim if you can...I removed the ground tab from my 91 stalk, and got it in the 89 stalk to make mine fit..however, you have to disassemble the stalk itself (lotsa small parts and springs and shit flying around) so be careful not to lose anything
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 08-22-2003, 09:59 PM
Re: headlight stalk
You are the MAN! I REALLY need to replace my headlight switch now cause now my high beams dont even turn on any more!! Thanks for the helpful information, i knew that somthing was wrong with the stalk...and by "stalk" you mean the lever right?
-2000 Civic Hatch
-1998 Lexus SC300
Old 08-22-2003, 10:04 PM
EFStali's Avatar
i have to have my head lights turned on before i can turn on the high beams..but i cant just flash on the high beams.
Name is Adam
