Old 08-21-2003, 10:52 AM
blade34609's Avatar
blade34609 blade34609 is offline
Battery Light?
Hi,
My battery warning light comes on every once in awhile.
Then it will go away then come back again.
What does this warning light mean?
Alternator?
THanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-21-2003, 11:17 AM
hybridnorthern hybridnorthern is offline
I would check for loose connections around the battery and alternator
Old 08-21-2003, 12:26 PM
feelsfast feelsfast is offline
Send a message via AIM to feelsfast
The intermittent blinking can also be caused by a faulty regulator inside of the alternator causing it to surge the amounts of voltage its putting out. Get a volt meter and check voltage at your alternator and at the battery. you should get at least 12 volts and max should be 14.4. I got readings between 12.4 and 18.8 from my faulty alternator and I replaced it and everything was fine. Make sure you do as said in the first post and check all connections. Hope this helps.
Yes my car is slow!
Old 08-21-2003, 12:36 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
In addition to the suggestions that others have posted, make sure you check the tension of the alternator belt itself. I had a similar problem a couple years ago. Over time the bolts holding my alternator in place had loosened just enough to ease the tension on the belt & the battery light would flicker.
