Old 08-21-2003, 10:13 AM
enriqkike enriqkike is offline
dexcool
I have a 2001 tahoe that have had no problems with but i have been reading all the problems with the cooling system problems due to dexcool. should i flush that stuff out my system and use the regular green antifreeze before this happens to my tahoe.
Old 12-10-2003, 06:35 PM
Joe_T Joe_T is offline
Re: dexcool
I have heard to avoid dexcool as well. I mistakenly used it when I swapped my water pump/radiator/hoses this summer and will be replacing it with enviro-friendly green stuff.
'01 BMW 330i
fuckin slow!
'98 Infiniti QX4
stock as a rock
'98 Tahoe 2dr 4WD sport
X5 HID's, 265/75-16 BFG's, stock motor
'93 Mustang LX coupe
heads/cam/intake + stock 302 shortblock
11.95 @ 114 best so far all motor
Old 12-11-2003, 06:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: dexcool
Even though Dex-cool is good for 100K, I recommend that it be changed at 50K.
Also pay close attention to your cooling system level, I have found that vehicles that run low on coolant are more apt to have clogging and contamination problems.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-12-2003, 10:05 AM
hauptjm hauptjm is offline
DexCool is a lot more complicated than this. Air totally contaminates the chemistry. When it is compromised, it crystalizes and rots the entire metallic system. Heater cores are the most susceptable. The ONLY thing to do is to flush it out of your cooling system and replace it with old-fashioned green coolant. Some GM mechanics who are either idiots or liars will tell you green coolant will ruin your seals - not true. I had many problems until I did the 5 hour acid wash flush and replaced it with green coolant. That was a year and 20K miles ago, and no problems. By the way I got a written letter from GM engineering stating that the green coolant WILL NOT harm the gaskets and seals.
By the way, it sounds simple, but the radiator cap has to be replaced as well with a newer version that reduces air infiltration and opens at a different temp.
Old 12-14-2003, 08:39 PM
99ssconv 99ssconv is offline
Re: dexcool
that is new to me and i have worked for gm for 15 years. where did you read this?
