Old 08-21-2003, 09:36 AM
markd91civic markd91civic is offline
Oil leak problem
I have a 91 4G4D and it has an oil leak that keeps getting worse. It is right behind the distributor. I know that it is a seal or gasket that is behind it but does anyone know what the name of it is.
If anyone could help that would be really cool.
Thanks,
Mark D.
Old 08-21-2003, 09:42 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
sounds like a valve cover gasket, they arent very expensive, (at least not in the UK)
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 08-21-2003, 09:49 AM
I just replaced the valve cover gasket like 3 weeks ago. It is coming from more of behind the distributor. It is all leaking out on top of the tranny. All around the valve cover is all clean.
IT is a D15B2 if it helps.
thanks 16valver
Old 08-21-2003, 12:13 PM
91zc 91zc is offline
There is a seal on the shaft of the distributor. Try replacing that seal and see what happens.
91 civic 4dr
b16a
14.8@94
Old 08-21-2003, 12:25 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
yeah dude...I think you want item #7 in this link...it's called an "O-ring"
click here
For only one part I wouldn't buy it at this place tho...They have a $5 handling charge for each order...For the $1.23 o-ring, you can prolly go to auto zone or even Honda for that part and save $$...however, when you are buying lotsa stuff, nobody beats Majestic Honda.
If I went to get this part I would call it the 'distributor shaft seal'....
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
