View Poll Results: how do you like to shift?
don't shift, automatic 1 8.33%
power shift 2 16.67%
let rpm level off, then shift, smooth ride 6 50.00%
let rpm shoot up between shifts, rough ride 3 25.00%
Voters: 12. You may not vote on this poll
Old 08-21-2003, 12:05 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
and does the clutch also wear when you disengage it or only during engaging?
Old 08-21-2003, 12:56 AM
asdfbeau asdfbeau is offline
i dont clutch more than i need to to shift the gear, and i dont let the RPMs drop(the RPMs don't fall like they do when you shift normally anyway). I have heard that its really bad for your transmission, but at 51k miles, my clutch still has a strong grip to it, and if i have to replace a clutch at 80k miles, then so be it.
I shift like I do because its the smoothest way possible. I rarely accelerate hard, so I don't think its doing as much damage as everyone has told me it does.
Old 08-22-2003, 06:05 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
i shift normal, an i downshift to slow (yes i know its tough on the clutch, but its something to do).
i match rpm through downshifts usually jus to keep my self entertained, and i keep the ride very smooth (as smooth as u can get w/ a clutch like this). most of the time im cruisin mellow.
racing is...a different story
clutch wears whenever it is working. so when ur doing either...engaging it (pushing it in) or disengaging (letting it out), its' gettin some work. the 2nd (disengaging) is harsher on it however...
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 08-22-2003, 08:59 AM
redmanjd redmanjd is offline
i dont down shift its hell on you motor not only your trans. i shift slow
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 08-22-2003, 06:20 PM
knorsk knorsk is offline
I take my car out of P to shift then past R and N and then into D4
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
Old 08-22-2003, 08:21 PM
Re: how do you like to shift?
its not like i down shift an have it run way up, i balance it out, an its at low low speeds...its really not that tough on the motor. yes, tougher on it than not doing it, but still...keeps me awake aye?
2003 Infiniti G35
Old 08-22-2003, 11:37 PM
Parsalian05's Avatar
Parsalian05 Parsalian05 is offline
Send a message via AIM to Parsalian05
hmmm, im a casual driver and i dont drive a manual much, but if i need to slow down or stop i just put the clutch all the way down and break... the only time i actually down shift is if im on the highway and the traffic slows down just a bit and i wanna keep rmps level. well lets say im slowing down to a red light (clutch down, breaking) and it turns green while im still going about 30, then ill just (carefully) put it into 3rd gear.
would this be a or ?.... or a
no ones ever really tought me everything there is to know about a manual tranny but i figure im learning progressively just driving alone.
-par
96tsi awd... 2.3L 6bolt in the making
Old 08-23-2003, 02:14 AM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
Hardly ever use the brakes, always downshift to stop, like to match RPMs through corners while downshifting to keep it smooth, wish my motor would blow up so i have an excuse to get a new one.
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 08-23-2003, 02:36 AM
BullShifter's Avatar
Why even bother with the clutch, except for 1st? Slip from gear - rev match in neutral - up/down shift.
I dont recommend trying that with your own car until it comes natural. If you dont do it right you will fuck stuff up. Better using the clutch because a clutch replacement is cheapier than a tranny/tranny re-build.
Old 08-23-2003, 09:49 AM
djK1 djK1 is offline
-par
btw you can brake without engaging the clutch, just engage and disengage into neutral when you are about to come to a complete stop...
Well, what is double clutching I have heard of it, but don't i know what it is...
Si-leeper: "Take'm by suprise"
Old 08-23-2003, 01:04 PM
rubix777's Avatar
I always thought the clutch wears most during engaging because I thought that if you disengage fast enough, there wouldn't be enough time to wear as opposed to allowing the clutch to slip during engaging.
I better get better mileage too, seeing as the 4th gen prelude I4 has an equivalent mileage as the accord v6. Maybe that's why they stopped producing preludes?
For power shifting, I'm kind of scared to knudge it in. Would the process be the same as a 10 speed bicycle where it just pushes the chain over? At how stuff works they give a good description of the manual transmission. But if manual transmission was similar to a 10 spd bike, then wouldn't shifting without the clutch be bad?
Old 08-23-2003, 08:22 PM
Double clutching - When shifting let out the clutch in neutral - rev match - push clutch in - shift. Double clutching will reduce synchro wear in a trans with synchros. Some race cars & older vehicles(mainly large trucks) dont have synchros so double clutching is the only way the transmission can be shifted. IMO its a waste of time in our cars - I try to use the clutch as least as possible & not at all! 50% of my shifts are without the clutch(up & down)
http://www.driftsession.com/drift_te...oeshifting.htm -- click there for further info & other driving techniques like drifting.
No if done correctly
Yes if not done correctly
How you like this integra?? zulux3 Integra 4 01-28-2004 03:28 PM
how you like my valve cover esp '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 38 09-09-2003 01:46 AM
How you like this kit?????? civic_1.6_16v Europe 21 05-28-2002 10:22 AM
Tower Strut Bars - what you have and how you like it Yahnozha Suspension 3 11-28-2001 03:43 AM
Tower Strut Bars - what you have and how you like it Yahnozha Cosmetics 1 11-27-2001 02:38 PM
