Old 08-20-2003, 10:30 PM
Axe91CVC Axe91CVC is offline
skunk2 front Upr Ctrl Arm "Question"
Been watching u regs chat on here for quite some time. Learned alot just from reading up on this forum
This is my first post (btw i'm only spelling everything out for the newbies cuz i was one once--didnt know squat & still learning ) I've researched this & havn't found a damn thing on it...
My question is--Will the front upper control arm from a 5th generation( 1992-1995 )civic hatch bolt up onto the 4th generation( 1988-1991 )civic hatch??? On my 4th gen I cannot extend the front upr cntrl arm out very far ( like if i was to use an ingals front camber kit----fully extended )w/o the arm hitting the fender well and interfearing with the suspension travel......only unless i was to do some cutting of the fender well BUT If i'm gonna have to do some cutting then i might as well get the SKUNK2 kit if it fits the 4th gen ( becuz IMO ingals front kit is retarded.....too hard to install, adjust etc. ) If the 5th gen Upr Ctrl Arm does fit i realize i am gonna have to do some cutting to the fender well......so thats no big deal ( i'm prepared for that) My main question again is WILL THIS ARM (from a 5th gen )BOLT UP TO A 4TH GEN????
If it does i wanna get a SKunk2 adjustable camber kit and slapppp it on there baby!!
SKUNK2 does not make the adjustable camber cntrl arm for the 4th Gen ( most likely bcuz there's fender well cutting involved ) but i was curious to see if there was another reason ( like if it is becuz it does not bolt up to the f-ckin thing at all ??? Thanx hope this is easy to understand
Old 08-21-2003, 01:27 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
I don't know the answer to your question, but one way that I have tested for exchangeability of parts is to call a dealer, ask for the part # to the first one, write it down, ask for the part # to the second one, and then compare. If they are the same, or similar, they will probably bolt on. It would be then that I would go to a wrecking yard and pick one up and try it out. It would sure be a lot less painful than getting the skunk2 kit and finding out it doesn't work. You might also try calling skunk2 and asking their advice.
Just my thoughts, hope they help...
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 08-21-2003, 06:09 AM
well my whole purpose in writing this post was to avoid the going to the junkyard....and skunk2 wont recommend puting the part on any other vehicle than what the part was made for......already called the dealer......part numbers are different
Old 08-21-2003, 10:21 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Does Skunk2 make a kit for the 90-93 'Teg upper control arms? I noticed on a previous post that Problem Si had the 'Teg upper arms on his 4g...
Old 08-21-2003, 04:31 PM
nope they sure dont make the front upper camber control arm for the 1990-1993 integra
still looking for another alternative to the ingals front camber kit
anyone know about this????
Old 08-21-2003, 06:01 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
look for JDM upper control arm made by vision. They are the only ones available for the fouth gen. www.jdmhondaparts.com
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 08-22-2003, 11:30 AM
9EF3ZC......thanx man u solved my problem!! YOU ROCK
i appreciate the info alot....
Old 08-22-2003, 07:21 PM
91EF3ZC's Avatar
AF Premium User
Re: skunk2 front Upr Ctrl Arm
No problem, anytime!!
Old 08-22-2003, 10:16 PM
ok ok ...um...i changed my mind...your IDEA rocks....but damn those arms
are expensive.......they want $320 YOU GOTTA BE KIDDING ME!!!
and i thought SKUNK2 was high!!! SHEEEEZZZZ WHIIIIZZZ
Old 08-22-2003, 10:22 PM
91EF3ZC's Avatar
AF Premium User
I know it is a bit pricey, but they are the ONLY upper arm like that out there. There is no competition, I guess they figure, if you want them, you will pay for them. I was going to buy them myself, but don't have the cash for them right now. I just hope when I do have the cash they are still available.
Mike
Old 04-27-2004, 08:49 PM
actually after calling some folks that sell these upper arms from VISION ......i learned that they dont correct the camber caused by lowering your vehicle.......they ACTUALLY make it worse..........
these are supposed to be used for racing purposes........they pull the top of the wheel inward....which makes for a more stable turn......
however this extremely shortens your tires life
How do I remove bushings from ctrl arms? FantasticChadwick Problem Diagnosis 5 11-21-2006 06:48 AM
Skunk2 Front Camber Kit loesch8102 Tires and Wheels 0 06-04-2004 05:35 PM
Replace Front Lower Control Arms jgardner72 3 Series 1 05-04-2004 03:49 PM
Front door panel arm rest repair Dangerisdan M Bodies 1 03-06-2004 05:45 PM
Right front upper control arm. Santas90Si '88 - '91 Civic | CRX | Wagon | Shuttlee 1 09-24-2003 02:32 PM
