Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-20-2003, 07:57 PM
mzr55 mzr55 is offline
Send a message via Yahoo to mzr55
turbocharging H22A
Greetings, I'm from malaysia.
Just booked my Prelude...will get it next week.. It comes with H22A auto tranny.
Plan to turbocharge it with serious boost...
So my question is what do I need to do besides stronger Conrods, Low Compression Piston, and metal head gaskets.....
What about engine management? I heard that honda's engine will stall if it sense +ve pressure... Is it true? If it is true how do I get around it? Should I change to other fuel management system or just an Apexi V-AFC will do?
Old 08-20-2003, 09:39 PM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
Re: turbocharging H22A
if it has ATTS (Traction Control) you may need to switch to a base model ECU, (if you don't have one already) - you will probably need a 3 bar map sensor, additional injectors and maybe a bigger fuel pump.. boost controller... should be it - maybe someone else has some input too... i have never turbocharged an H22 but im sure someone else has so they can correct me where i talked out of my ass...
Old 08-20-2003, 10:12 PM
as for the 3 bar map sensor, where can i find it? why can't i use the ecu with tcs...? mine came with tcs..
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
turbocharger or supercharger J_U_ice Forced Induction 3 05-18-2009 09:07 PM
Twin turbocharging Vs. single turbocharging. Hypsi87 Non Specific 31 04-23-2005 08:26 PM
Help!! H22a or H22a Type-S worth it? Mr. Anderson Engineering/ Technical 4 02-15-2003 10:46 AM
Anyone want to turbocharge their max? Why supercharge when you can turbocharge? 2k2max6sp Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 05-12-2002 11:15 PM
