can anyone back this list up??
well i found this on hondatech.com and i was wondering if it was all true......here it is...
Water Pump 19200-P30-003 94 - del sol Head Gasket 12251-P30-014 94 - del sol Oil Control Orfice O ring 15142-PH3-003 94 - del sol Intake Manifold Gasket 17105-P30-004 94 - del sol Exhaust Manifold Gasket 18115-P30-013 94 - del sol throttle Body Gasket 16176-PR3-010 90-91 integra Pcv valve 17130-PM6-G01 94 - del sol Timing Belt 14400-PR3-004 94 - del sol Alternator Belt 31110-PR3-003 94 - del sol Tensioner 14510-P30-003 94 - del sol Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) Cap & Rotor Assembly 06303-PR4-000 90-91 integra Rotor (If needed seperately) 30103-PR3-016 90-91 integra Clutch Cable 22910-SK7-A02 90-91 integra Throttle Cable 17910-SK7-A03 90-91 integra Cam Seals (2) 91213-PR3-004 94 - del sol Oil pan seal 11251-P30-004 94 - del sol Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol Oil Filter 15400-POH-305 94 - del sol Oil Pick Up Gasket 15221-PW0-S01 94 - del sol ***** Pin Shift Linkage 91 crx si ??? Shift linkage bushing 54303-SB2-010 90-91 integra crank seal 91212-PR3-003 94 - del sol rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) Valve cover grommets -8- 90442-P30-000 94 - del sol Spark Plug O rings (4) 12342-P66-000 94 - del sol Rubber plug for exhaust cam tranny side 94 - del sol Spark Plugs (4) BKR6E-N11 NGK Spark Plug Wires 32722-PR4-A01 92 - integra gsr Upper Radiator Hose 19501-PR3-000 92 - integra gsr Lower Radiator Hose 19502-PR4-A00 90-91 integra Bypass Hose (Thermostat) 19508-P08-000 94 - del sol Washer for coolant drain on block 90401-PR4-000 94 - del sol" can sumone tell me if it all sounds good and will work those are parts for a b16......thanks |
altenator belt is 90-93 teg, Del sol may fit though
Oil pan gasket any B series Motor will fit The Upper GSR Rad Hose is hard to find and a dealer only Option. I personaly used a 90 teg LS hose. Clutch cable I used my D16A6 one. altenator is a 90-93 teg
2012 VW Golf 3 Door Automatic (Company Car) 2011 VW Golf Wagon 5 speed (Company Car) 2010 VW Jetta 2.5 Automatic (Company Car) 2009 VW City Jetta 5 Speed (Company Car) 2009 VW GLI 6 Speed (Company Car) 2008 VW Jetta 2.0T 6speed (Company Car) 1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold 1990 CRX Si (Built B17a) - Stripped and Crushed 1988 CRX Si -- Stolen 1990 Civic Cx -- Sold 1990 Civic Si -- Parted 1989 Civic dx -- Sold |
www.hasport.com has a part list of what fits where, but 99% of the parts from the 94 sol will interchange.
i got my GSR upper hose from www.autobarn.com
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
