Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-20-2003, 12:23 AM
sleepers sleepers is offline
Send a message via Yahoo to sleepers
knock sensor esc code??
replaced engine on a 95 Bonnevill with 3.8 Gives code for knock sensor problem. Any body know the resistance in the sensors should be? Or come across this problem. Also have the same problem with 90 Pontiac Grand Am 3.1 engine? Thanks
Old 08-20-2003, 01:50 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
First check the voltage at the knock sensor wire. Should be 5 volts.
Resistance reading of the knock sensor is around 100k ohms.
Most knock sensor problems I have encountered are due to a poor connection between the connector and sensor.
My suggestion would be replace the connectors on the sensors. A pigtail kit is available from GM parts.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-21-2003, 12:50 AM
Wink
thanks for your help
SES code help redfox3369 Venture 1 04-09-2009 12:42 PM
Knock Sensor Trouble Code evildragon Caprice 10 01-08-2008 10:12 PM
Knock Sensor PO327 code set Mike Loew Problem Diagnosis 6 11-10-2007 11:36 PM
Motor pings, knock sensor computer code JWMAX Engineering/ Technical 4 03-12-2004 08:07 PM
