Old 08-19-2003, 07:35 PM
kdolson kdolson is offline
Unhappy Keyless Entry
I have a 1999 Silverado LS would like to know how to program keyless remotes.Tried owners manual didn"t work,put in new batteries.Dealer in this town want's $60.00 is it that hard to do.
thanks
daryl
Old 08-21-2003, 03:38 AM
Chevy2xtreme's Avatar
Chevy2xtreme Chevy2xtreme is offline
Im sure it would be easier to just pay the $60 that way you wont have to deal with programing the computer if you even know how
My Car:S-10 Xtreme ext.cab LS
color:RED
Enigne:4.3 v6
Year:2002
Hp:225
Mods:
-Wireless Neon Underglow
-Dual Exhaust
-HyperTechPowerProgramerIII
-Lowered 2'' in the front 1'' in the Rear
-New Headlamps And Ice Bulbs
-Modified Air Box
-Polished Stainless Steel Sidebars
-locking taune cover
Future Mods:
-IntercooledSupercharger
-Euro Lights
-Flame Decals
-Rims
Old 08-26-2003, 09:14 PM
djpbaby djpbaby is offline
First, make sure your new key fob (the transmitter) id number on back matches your old one. If they match, do this procedure:
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
Old 09-26-2003, 03:15 PM
Smile Re: Keyless Entry
This worked great Thanks
Old 09-27-2003, 02:51 AM
cobra1 cobra1 is offline
Re: Keyless Entry
ohhhhhh yeah............. i know i'd rather pay someone $60 for something that only takes 60 seconds. -not
bet your dealer loves to see you coming.....
Old 09-28-2003, 04:09 PM
gmc gmc is offline
Does this work for all years with gm? (1999-2003) Would this procedure work for a 1998 silverado?
1998 Z71
5.7L
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
