Old 08-19-2003, 07:47 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Damn car, help me plz, for am i stumped again
Ok, my hella bad luck car has done it to me again. Last night it wouldnt start at McDonalds, just cranked, wouldn't turn over. Then this afternoon at like 1 pm i went back to it and it did start. So i drove it home, then left like 20 min later and it started fine again. But then leaving my neighborhood goin on to the main road the car just died while i was still in first gear in the middle of the road. I managed to get the car off to the side of the road but then still was only cranking. That was at like 2, then again at like 6 30 i went back, still wouldnt start, i tried pumping the gas alot before and while it was cranking. So we pulled out the spark plug wires to see if there was a spark (not sure if we did it right) and we didnt see a spark. So i went out and bought a new distributor cap and put that on, but it still wouldnt start. So now i have no idea wat it could be unless maybe i flooded the engine with all my gas pumpin i did, cuz i was doing it for like 30 sec straight. Heres some info:
-Battery is Optima Redtop, new
-Alternator is like 1 month old
-Spark plugs/wires are only like 5 months old
-Distributor cap is like 20 min old
-Ecu isn't giving me any codes
-I've never had a problem with the car starting until last night, and it was quite cool outside, then did start in the heat (so i dont think its the main relay)
If anyone has any idea wat the problem could be or if i may have flooded the engine so it just needs time now that the distributor cap is replaced, plz let me know asap.
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 08-19-2003, 08:05 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Try replacing your rotor (and or making damn sure that it's on the post tight)?
So, if your car won't start, and you know the starter is cranking, it's either because of air, spark, or fuel... Throw a timing light on that bitch and see what happens... are you getting a CEL? If you're sure you're getting spark, pull an injector and crank the ignition to see if you're getting fuel. Check your ignition coil by measuring the resistance of the primary and secondary windings... just to name a few ideas of what you might wanna check...
Old 08-19-2003, 10:06 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
if its a fuel problem, could be fuel filter, if its a spark problem check the ignitor/coil
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 08-30-2003, 03:53 AM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
hey i dunno if this might help but my civic used to stop running when at idle and once stopped running on the freeway. my dad replaced this chip inside the rotor/dist. cap. i forgot what it was called but it was about the size of a half dollar coin and costs about $100. that fixed my problem
Old 08-30-2003, 04:15 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i think hes talking about the ignitor. if u could get yoru hands ona replacment dist that u can try
Team Lonely Drivers
Old 09-12-2003, 09:27 PM
tylertime tylertime is offline
if your car still doesn't start check the ECU fuse under the hood
my car would blow that occasionally for REASONS UNKNOWN but it did it like 5 times all at slow speeds i had to keep the revs up to keep it running
did this till i changed main relay GO FIGURE???
RHD Cars Casting Call for a TV Show morgan8er Southern California 0 09-19-2009 07:30 PM
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 01:32 PM
New Car! Help Plz!! kmking420 Exterior | Bodykits | Lighting | Aerodynamics 3 09-16-2004 03:17 AM
