Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-19-2003, 04:10 PM
jersey_golf_dude jersey_golf_dude is offline
Unhappy 2000 Maxima - alarm
I just bought a 2000 Maxima GXE.....great car. I do have one problem, the alarm seems to be overly sensitive to vibrations (heavy bass from a radio, slamming of door next to the car, etc.) Is there any way to adjust this?? Or can someone tell me how I can figure out if it is factory or after-market.
Thanks in advance.
E
Old 08-19-2003, 04:25 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: 2000 Maxima - alarm
Thanks in advance.
E
What's up golf-dude, welcome to the forum. I have the same car as you (mine's is white) and I've never had any problems with the alarm, that is the first I've ever heard of bumps/heavy bass or doors slamming setting it off.
It sounds to me as if there's an aftermarket system on your vehicle, you may want to recheck your alarm connections and check your fuse as well. If not that then if your vehicle is still under warranty, take it into the dealer and have them look at it to see what's up with that.
Once again welcome to the forum and we'll be looking forward to seeing more from you.
2 fingaz=Peace
By the way, it should read bk2k3Max, not bk2kmax.
Old 08-19-2003, 07:21 PM
leftony leftony is offline
I,m no expert but I just bought a 2001 Maxima GLE and had this exact problem.I do have 2 alarm systems.The one that was overly sensitive was the aftermarket one.This may be your problem as well.Now to correct this problem.As I was snooping around I found a little black rectangular box on the floor just ahead of the brake pedal.The box has two(2) markings.1 is "MORE SENSITIVE" 2 is "LESS SENSITIVE". Mine was adjustable using a very small slotted screw driver.I turned it towards the "less sensitive" direction and that was it!
Hope this helps.BTW does your "PANIC" button work on the key fob? Mine doesnt and I think that it has something to do with the aftermarket unit being hooked up.Good Luck.Tony.
92 maxima alarm won't go off christyfisher Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-06-2004 05:56 PM
93 Maxima alarm won't turn off drummindrummer Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 07-28-2004 12:45 PM
1985 Nissan Maxima, alarm system mariasolci Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 06-25-2004 02:29 AM
bulbs in 2000 maxima focalBlur Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 08-28-2001 12:53 AM
New to the board...what can I do to pep up my 2000 Maxima GLE? Cane1992 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 05-10-2001 07:53 PM
