Old 08-19-2003, 11:56 AM
wagz182ksu wagz182ksu is offline
Unhappy .
Old 08-19-2003, 06:43 PM
nemesls_2000's Avatar
nemesls_2000 nemesls_2000 is offline
Send a message via AIM to nemesls_2000
Unfortunately, many aftermarket part companies do a crappy job sealing tail lights and headlights. The easiest way is to take your headlights off and put them in your oven. Set it for 350 degrees and set the timer for 5min. This is to soften up the silicone that seals the headlamp housing from the glass. If you don't want to put them in the oven, use a heat gun to loosen up the silicone. After the silicone is loose, clean all of the remaining water/moisture from the headlamp with a soft clean towel. You will need to buy some silicone from your local Lowe's or Home Depot. I recommend either clear or black. Place the silicone around your headlamp and place the glass back. Let is sit overnight or whatever the recommended drying time is on the bottle of silicone that you buy. This process can also be done on your tail lights if you want to paint the housing on any old red/clears or altezzas that you have.
Mods:
AEM intake, DC Sports 4-1 header, Tanabe exhaust w/ 2.5" custom piping, ITR exhaust cam, APEXi VAFC, AEM FPR, Warlboro 255l fp, RC 440 injectors, ACT stage 3 clutch, JR Supercharger, Weapon R coilovers, VIS CF vader hood, CF Angel Eye Projector headlights, Black housing corners w/ amber bulbs, "Hybrid" rear emblem, custom rear speaker panels.
Old 08-25-2003, 01:22 AM
jfoghino jfoghino is offline
Question
I have a question about your angel eyes...I'm assuming they are crystal clear and my question is, do they disperse light evenly in front of the car? I bought a set of Inpro H4 Crystal Clear headlights and the light seems to shoot straight out as a beam and doesnt disperse well. I dont have much light out to either side of the light path. Let me know how yours performs plz. Thanks!
Old 10-02-2003, 08:07 AM
saranaz saranaz is offline
Send a message via AIM to saranaz
Lightbulb anjel eyes
yea i have the same problem, i just got sum last friday and in the morning, or late night they fog up when its cold, i havent tried silicon yet, but i have opened the little rubber elbows that let air in/out, they were sealed b4 so im trying this, if this doesnt work, im going to seal them up and silicon the sides up......
-saranaz
Old 10-02-2003, 06:58 PM
hondaracer hondaracer is offline
Re: anjel eyes
Yeah I would just get the silicone and solve that problem....
Old 11-13-2003, 03:11 PM
dragonstylez89 dragonstylez89 is offline
Re: Re: anjel eyes
You know after reading all these I was thinking about taking off my headlights but since i didnt know how to install them i paid someone to do it. My new projector dual halo headlamps had moisture in it but then I thought it was cuz of the bad silicone sealing like everyone says it is. But what i figured out was that the moisture went into the lamp while it was being installed cuz it was a rainy day. Well I just took out the high beam lights so there is a big hole and covered it up with the rubber thing. I waited the next day when it was sunny and opened the cover and let it all dry out. I would prolly use a blowdryer but didnt have an extension cord. Then I just put the high beam bulbs back in and closed it back up. I havent had a problem ever since! Which was like 2 days ago but still....i'm glad i didnt have to do all that silicone stuff.....good luck
Old 11-14-2003, 12:06 AM
93CivicLx's Avatar
93CivicLx 93CivicLx is offline
Re: Moisture problem in new angel eye headlights
Burn Halos in OVen Yah.!!! yEAh .. hehehe FIRE FIRE!!
"H to the izzO N to the D A"
Old 11-14-2003, 01:50 PM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
uhhhh
1997 Integra GSR and 1992 Civic LX
