Old 08-19-2003, 11:24 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
heat problems
i live in orlando and it gets pretty hot down here in the summer and for some reason when my car is parked out in the sun where there is no shade it doesnt want to start right away, i have to leave the key in the on position and let the fan run for like 1-2 min. i just changed my starter like 4 days ago so i know its not that cause at night when it cool outside it starts up right away.
so c if u could answer my question
Y LOOK FAST WHEN YOUR NOT?????????
Old 08-19-2003, 02:33 PM
daddys's Avatar
daddys daddys is offline
its your main relay,, you can get one at a honda dealer and its located behind the coin box
Old 08-19-2003, 06:51 PM
D15Bitch's Avatar
D15Bitch D15Bitch is offline
I periodically get the same problem. All I do is clean all the electrical contacts on the starter motor, the relays and make sure no engine grime is anywhere near the electrical stuff. Use some sand paper to bare the metal again, for proper contact. If you struggle with this, use some engine cleaner in a can to remove the grease & grime. Mine always starts up again immediately. After several months if it happens again, I clean it again, and it's gone again...
Old 08-19-2003, 07:11 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id suggest you replace the main relay as well, but i think its behind the hood pop thingy.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
