Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 08-19-2003, 12:24 AM
JuMBoBeaTS's Avatar
JuMBoBeaTS JuMBoBeaTS is offline
Send a message via AIM to JuMBoBeaTS
i need ideas on strobe light placement...
wassup guys... i recently copped a pair of strobe lights... 2 sets.. one for the front n one for the back... ive got an idea where to put the ones for the back (i was thinking of placing them in the turn signal chamber of the taillight)... but im not sure where to put the front ones... i was thinking of somewhere in the headlight... what did u guys do? if it makes any difference, i bought the strobes that are by hiper... the strobe is a small straight tube, covered by a plastic sheath, and seated in a rubber grommet... i'll post pics if necessary.. thanks in advance
2000 honda civic EX 2dr black
Turbo Future...
Old 08-25-2003, 03:23 AM
BrandonClaps BrandonClaps is offline
Send a message via AIM to BrandonClaps
i mounted my police strobes directly under my headlight bulb in the headlight housing of my 2k si
Old 08-25-2003, 03:31 AM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
you would assume as close to the headlight bulb as possible would = maximum reflectiveness.
Old 08-25-2003, 09:10 AM
depends on where in the headlight housing, could reflect off the highbeam or lowbeam reflector
Old 08-26-2003, 12:28 AM
JuMBoBeaTS's Avatar
how did u mount it?? did u just drill a hole?
Turbo Future...
Old 08-26-2003, 02:30 AM
BullShifter's Avatar
Yes just drill a hole. Make the hole towards the lower part of the housing. That way if any water gets in from a bad seal it has a place to drain. Just make the proper sized hole & possibly seal with silicone to prevent any leaks.
