Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-18-2003, 08:13 PM
RicR_wana_B RicR_wana_B is offline
gauge isnt workin
i got a 93 ford ranger and the gas gauge is NOT working at all ... i took it out to see if anything was broken but its all ok but some power too it and it works from there but whenever i turn the truck on nothin happens it just kinda sits there... and a buddy a mine told me it could be the float in the tank that isnt workin... so just need some info on what u guys think it might be...
Old 08-19-2003, 12:47 AM
Jeff726 Jeff726 is offline
It may run you some money, but my wife's 97 ranger had a similar problem. We replaced the entire fuel pump and sending unit assembly. Works like a charm now. Be sure to test with a digital multimeter.
Old 08-23-2003, 01:35 AM
spdracr87 spdracr87 is offline
Send a message via AIM to spdracr87
so it doesnt work when unless u mess with teh wires to the gauge to giv eit power? if so u need to check to c if your ground is strong and connected good. also run a u can c if your float is stuck buy. siply takeing out and cing if it slides up and down or not it takes like 5 minutes after u take the bed off but really long time if u try to with out the bed off. well i think its either you float or like i said the ground wire on the gauges. it might even just be a shorted wire. helps to get a voltage tester and check all that. and like if u put a system in that truck with out a kompasitor then that can do it to cus its takeing to much power from the fuel gauge and maybe even some fo the others. well let us know
1987 honda crx si.
under hood mods.
1. custom built cool air intake
2. 4/1 header.
Exhaust
1. high flow cat.
2. and pace setter cat back tooned exhaust.
sytem soon to come cab is being custom painted maybe. and out side is being painted soon.
FOR SALE!!!!!!!!!!!!!!!!!!!!!!
