Old 08-18-2003, 03:50 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Question How to remove front bumper
Hey, I need to know how to remover the front filler piece and the front bumper on my 91 HB. I took the one bolt on the front of the filler piece off, but it won't come off. Is there more?
Old 08-18-2003, 03:59 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
With the bumper i took off all the bolts i could get to, then i got tired of messing with it so i just yanked it off. and with the filler piece i unbolted it on the sides where the corner lights are, i could not get to the rest of the bolts so i just started bending and breakin and cut it off. YOu could prolly do this without tearing anything up by taking the headlights out, but i spent about an hour trying to take them out, then i just said fuck it and started tearin stuff. but it all worked out right.
KoRnSaQ
Old 08-18-2003, 04:23 PM
Carnivore's Avatar
Carnivore Carnivore is offline
Send a message via AIM to Carnivore
hey KornSaQ......whats with the gap below your right tail light?
I love my honda...I hate my honda
Old 08-18-2003, 04:26 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: How to remove front bumper
Yipes... that's an expensive way to remove a bumper!
Anyways, for the bumper, there's 2 screws in each wheel-well. I had to jack my car up to get at them properly.
Then there's 2 bolts underneath the bumper holding it to the radiator support (so you might as well jack the car up anyways).
There's also 2 bolts behind each of the bumper lenses, so you gotta take them out...
Then lift and slide the bumper towards the front of the car. It's kinda heavy with the reinforcement in it... Just a heads up so you don't drop your bumper...
Then if you need to remove that trim piece above the bumper and below the headlights, there's a single bolt in the center of it, and then there's a bolt on each end of it underneath the corner lenses.
All in all, a very easy thing to do...
Installation of the bumper back onto the car is the same in reverse. But, make sure you get the side clips on the bumper to slide into the clips on the car by the wheel-wells...
Old 08-18-2003, 06:06 PM
Thats where the i could not get the top of the rear apron to go all the way onto the bracket, i have got it fixed now though, i guess i should update the pic.
Oh yeah just so you know, i was talkin about me yankin off the plastic bumper, I never took off the steal bumper.
KoRnSaQ
Old 08-18-2003, 06:12 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
what about the back bumper? how woul du go about taking and replacing it?
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 08-18-2003, 06:58 PM
ci5ic's Avatar
I think there's some screws in the wheel-wells for that as well, and then, you have to remove your brake lights on either side to get at some bolts under there. Not sure what else there is, I've never actually done it myself, but check under the bumper as well...
Old 08-18-2003, 07:10 PM
The back is almost the same as the front, cause to take it off correctly you need to take off the taillights and the metal piece between the lights and the bumber, but it is a pain in the ass to figure out how to take that metal piece out, So all i did was take out the Lights, take out all the bolts and screws i could get to, then i just yanked the plastic bumper off. Then you just get your other bumper and put it into the brackets, then make sure you have it screwed into the brackets on the sides(It will be in the wheel well) and the you need to try to get some screw through the bracket along the top/middle of the bumper. And of course whenever you buy aftermarket bumpers you are goin to have to do some modifications to make it look, and line up right.
KoRnSaQ
