Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 08-18-2003, 02:49 PM
Import_fantasy's Avatar
Import_fantasy Import_fantasy is offline
Smile Mods to the suby so far L@@K!!!
Black 02 WRX
-injen cold air intake
-mrt top mount intercooler
-gfb pulleys
-gfb BOV
-HKS downpipe
-modified upperpipe
-blitz nur spec exhaust
-3 inch straight through pipe between down pipe and blitz rear section/muffler
-intercooler spray kit
-AVO short shifter kit
-walbro fuel pump
-greddy profec boost controller
-APEXi S-AFC
-MRT sway bar links front and rear
-MRT front and rear sway bars
-whitline anti lift kit
-18in. OZ prodrive p1 wheels(gunmetal)
-goodyear eagle f1 tires
-MRT hood scoop
-JDM emblems
-sti fog light covers
-JUN eyelid headlight covers
-carbon fiber side marker covers
plans to add:
-vf22 turbo
-sti injectors
-clutch, flywheel
-JDM headlights
-JDM gauge cluster
-more body work
Old 08-18-2003, 09:21 PM
XspudX's Avatar
XspudX XspudX is offline
Send a message via AIM to XspudX
Nice list
Old 08-19-2003, 11:15 PM
RockinWRX RockinWRX is offline
Send a message via AIM to RockinWRX
Re: Mods to the suby so far L@@K!!!
Originally Posted by XspudX
Nice list
What he said. But why would you get the loser IHI VF22 when you can get an 18G that bolts right up and doesn't have near the lag. Mitsubishi turbo's RULE.....
And don't forget about tranny upgrades. Prolly the 1st thing you should do , if this car is gonna be used to anywhere NEAR its potential. 1st and 2nd gear both like to shatter if loaded up too far , I'd at least consider an STi upgrade , and more likely a B+M or TRE tranny build.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap.
'03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
Old 08-20-2003, 01:36 PM
what do u know about the vf22? i have found very little info on this turbo?
Old 08-20-2003, 04:17 PM
I beleive the VF22 is comparable to the Mitsubishi 20G for power output. About 450 Hp. I know there are quite a few complaints about the IHI line in general , because they are very laggy and peaky. Spool up on the VF22 is supposed to about 3300 rpm , the 18G spools at about a 1000 rpm lower. The Mitsu 18G is a direct bolt-on , no adaptors required , and is prolly about a 425-450 Hp turbo. You'll want to get bigger injectors than the STi's , in that case , because I beleive the STi's are only good to about 400 Hp , if that.
Oh , and just do a keyword search on "VF22 turbo"
Old 08-23-2003, 03:26 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Sounds like a cool car, now you have to get some pics up and prove that its a cool car.
