Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-18-2003, 12:44 PM
easyc4 easyc4 is offline
Need Help!!! Radio/antenna
I was putting in an aftermarket radio in my 1990 century, i did not avhe the money to buy the correct harness, so i just got a wiring diagram and cut fof the factory harness and used wire connecters to connect all the wires correctly, unfortunately, my jvc radio did not ahve a wire for the power antenna, so now, when the battery is plugged in, the antenna continually tries to move up, but doesn't, and does not stop at all, is tehre any way that i can jsut turn off the motor for the power antenna, or how can i fix this, thanx.
Old 08-18-2003, 06:13 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Unplug the power antenna!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 08-18-2003, 11:18 PM
how? where is the plug for me to unplug? i knwo jack about the locations, so any details would be great
Old 08-19-2003, 08:00 AM
pcv pcv is offline
Below the antenna is the motor. On it is a relay for the motor. Just un plug it or there is a plug that goes to the motor itself. Unplug that. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 08-19-2003, 09:37 AM
ok thanks, now i jsut gotta figure out how to get to teh motor b/c its inside the fender
Old 08-19-2003, 03:46 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Open the trunk.
pull off trunk lining, carefully, around the antenna.
unplug the power wire.
replace trunk lining
close trunk.
turn on radio, cruise, and have a drink!
