Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-18-2003, 10:51 AM
Antonioxp Antonioxp is offline
Exclamation Stuck Ignition Switch
Any ideas about an ignition switch that doesn't turn? I've tried wiggling the steering wheel and making sure the car is in park. The switch simply won't budge. This is my mom's car and I don't know it at all. 1992 Grand Marquis. Any idears out there? Thanks!
Old 10-02-2003, 09:50 AM
BDK-Nairb BDK-Nairb is offline
When is the last time the car was used? I know in my '78 grand marquis I had to use plyers just to turn the key back to accessory only. It could be a similar situation for you. You could always hot wire it. Just use plyers and if it doesnt turn over then it will break and pop off leaving you with exposed wire to use at your leisure
Old 12-07-2003, 10:33 PM
BgDg3086 BgDg3086 is offline
Send a message via AIM to BgDg3086
Re: Stuck Ignition Switch
Is the steering wheel locked too? If so, you need to turn the steering wheel one way and then turn the ignition.
Old 01-04-2004, 12:27 PM
MaxPowers_68 MaxPowers_68 is offline
I had a similar problem, they had to replace it.
Old 02-14-2004, 11:18 AM
Maxpen Maxpen is offline
Check, or replace, your key(s). They may be worn and not moving the tumblers correctly.
Old 04-05-2004, 12:56 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I hear that replacement is the way to go on this.
Old 05-22-2006, 11:45 PM
richter111 richter111 is offline
actually a common problem on Ford Ignitions. Replacement is the way to go, and actually not too hard if you want to do it yourself
Old 07-11-2006, 03:08 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
This post is a little late but the problem I had on my 91 was a bad ignition lock cylinder. The chrome part(like wings) where you put your fingers to turn the cylinder actually loosens up from the rest of the cylinder and causes the key to look like its bent. When this happens the key will not go in all the way and you cant turn the lock. If you look close you can see this looseness and the fact that the key wont go in all the way. Bought a new lock at NAPA and had it re-keyed by a locksmith. Total $45 and works great!
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
