Originally Posted by Neutrino
yes for starters don't call it NOS...just call it nitrous or N2O.....
second just get a good dry system....venom 2000 is the best...properly set up it will make sure you don't run lean.....
with shots up to 50hp you dhould be OK
I wouldn't recommend the VCN2000 to anyone, ever. I installed a kit on my brothers F-body, for starters 1300 dollars for the kit is a total rip off, for the 1300 bucks you pay for it you could have yourself a good direct port kit and all the safety stuff needed. The system takes a good 15-20 seconds to power up, which is more than enough time for the light to go green if someone lines up next to you. Lots of people have had problems with the venom not pulsing the injectors for the additional fuel, it's just too compicated for something as simple as nitrous. A good NX, NOS, or nitrous works dry or wet kit, WOT switch, RPM switch and fuel pressure safety switch is just fine.
