Old 08-18-2003, 02:37 AM
hardball_7 hardball_7 is offline
Question Idle Problems
I have never had this problem with my car before, but after I got my oil changed the other day my car had been having idle problems real bad. Getting the oil changed may have nothing to do with it, but it just started acting up right after I had it changed. What happens is when I come to stop lights or to a cpmplete stop it gets real low, almost to the point where you can't even here the car running. I have not cats and 3 1/2 inch tips on my car, so when it is on you can normally here it with out any problems. It completly dies some times as well. It either happens when I am sitting still at the light for a little while, or when I am slowing down, to come to a stop at the light. Do you guys have any ideas on what might be causing this? All the fuel, and electrical wiring is stock, so I am not sure if this needs to be upgradded. Or would a simple tune-up do the trick. Please let me know what you think.
Thanks
Mustang Mods: 3.73 gears, Mac off road pro-perfprmance h-pipe, Mac 2.5" cat-back w/ 3.5" tips, Mac Underdrive Pulleys, Cold Air Intake, 17" Cobra Rims, Mac 5.0 Shifter.
Old 08-18-2003, 10:55 AM
GreyhoundMom GreyhoundMom is offline
Send a message via AIM to GreyhoundMom Send a message via Yahoo to GreyhoundMom
Re: Idle Problems
I had a somewhat similar problem with mine a year or so ago, except mine would not stay running. It would crank, but wouldn't stay running unless I was actively giving it gas. It was the idle regulator (I think that's what it was called). Once I replaced that, it was fine. Don't know if this would fix your problem or not, but it's worth a try.
Old 08-18-2003, 02:05 PM
Ok I will look into it. I have just gotten to the point where I keep my foot on the gas slightly just so my RPM's stay up. When I do this it seems ok, but other wise it will jsut die. I only had one problem with it not wanting to start back up. Other than that I only have to turn the key a couple of times and it will start right back up.
Old 10-10-2003, 09:33 PM
90Stangjc 90Stangjc is offline
It could be alot of things, your idle speed could be too low, your fuel filter could be clogged, your choke could be adjusted wrong or it could be sticking, your distributor could have gotten wet or messed up, your spark pluges could be gapped wrong (did you do a tune up with the oil change?), you also could have a vacuum leak at the fuel injection unit.
Old 10-10-2003, 11:16 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
my guess is either fuel filter or iac sensor, check em out. why not replace the fuel filter anyways, they are real cheap and easy to replace!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-11-2003, 12:38 AM
IthePeople IthePeople is offline
Send a message via ICQ to IthePeople
hows your air filter?
mabey they spilt some oil on the filter, lol
im just shootin in the dark a million things could be wrong with it
take it to a garage for a FREE estimate they will tell you
go big or go home
fuck imports
