Old 08-18-2003, 03:28 AM
GreasyMexican's Avatar
GreasyMexican GreasyMexican is offline
Send a message via AIM to GreasyMexican
Question weird starting problem
My 97 Lumina 3.1 has this weird starting problem. Sometimes it starts sometimes it does not. When it does not start, I leave the ignition on wait anywhere from 2-5 min turn it off then it starts right up. If I wait to long then I have to let it seat for about 20 min. It is really driving me crazy if anyone could help, I would really appreciate it.
Old 08-18-2003, 09:27 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Well, your not suppost to leave the key turned for more than 15 seconds. Does your engine turn over fine? If so, you might not be getting spark.
Old 08-18-2003, 02:26 PM
As soon as I put the key, in it I try to start it and it does not turn over so I wait with the ignition on and it starts after 2 to 5 min.
Old 08-18-2003, 03:53 PM
Your starter is proberly bad. So after about 2 mintues your engine will finally turn over and start?
If i am correct, Im pretty sure your starter is bad.
I will ask my dad, and see what he says.
Old 08-18-2003, 03:56 PM
Ya sometimes it takes 2 min but most of the time it will take around 5.
Old 09-05-2003, 08:02 PM
dadada1651 dadada1651 is offline
I had the same exact problem. I was getting pissed off, then I realized that there was a Security Light that came on. I looked it up in the manual. It turns out that the light either comes on when u use the wrong key, and makes it so you can start the car for 3 minutes, or it tells you the sensor that reads the chip on your key is messed up. It is also possible that your key is dirty or wet or the sensor is dirty. My 5 dollar fix was a can of canned air, sprayed in the key hole a lot, and haven't had a problem since.
You may also want to wipe your key off with some rubbing alcohal, just to make sure it is clean. I hope I helped.
Old 09-06-2003, 08:32 PM
thanks i will give it a try
Old 09-06-2003, 08:43 PM
Forgot to say, if that doesn't work, then you will probobly have to take it to a chevy dealer, and they will probobly charge u an arm and a leg to get it fixed
Old 09-07-2003, 02:04 AM
ya the guy and chevy said anywhere from 600 to 1300 to fix it
Old 09-13-2003, 11:51 PM
My car is begining to do it again, I think it only does it when it is really humid out
