Old 08-17-2003, 10:29 PM
tanner07's Avatar
tanner07 tanner07 is offline
first real model, progress
Hi, I'm new here and I have only ever built a couple models in my life, never really finished one. I've been looking around this site and it looks like it could be fun...so I bought a '69 z28 RS (The same one primeraman did awhile back I guess) kit and some other stuff, but I had most of my other stuff that I needed from previous models. I am a beginner and don't really know how to do much, but I HAVE looked around at how-tos/FAQ. I have only just started this model and painted parts of the engine, and did th e chassis and some other stuff. This probably isn't making much sense because I suck at writing. I thought maybe I should start a thread so I could ask some quesitons about it as I go along? Well, here's what I've done so far
Engine block/tranny painted, cylinder heads painted and some chassis stuff done and painted
http://www.hpphoto.com/servlet/LinkP...6315562b&size=
http://www.hpphoto.com/servlet/LinkP...51d611ba&size=
Old 08-17-2003, 10:59 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
looks good
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-17-2003, 11:13 PM
tanner07's Avatar
thanks, in primeraman's thread about the same kit as this, he said he had the engine wired. How do I do that? or get the materials?
Old 08-17-2003, 11:20 PM
chipanggo's Avatar
chipanggo chipanggo is offline
very nice!
Old 08-18-2003, 12:27 AM
tanner07's Avatar
I have another question that I might as well ask right now before I forget about it..Will normal masking tape work for masking off the chrome trim around the windows (and other parts too)? If not, what kind of tape should I be looking at to buy, where can I get it and what do the prices range in? When primeraman said he foiled the chrome, how do you do that? I know these are stupid questions, but I would appreciate if someone could answer them, since I would like to get into this if I like how this model turns out. Thanks in advance
Old 08-18-2003, 12:57 AM
First off I love the Nova in your signature! And your Camaro should come out great, what are you're plans for it?
1) To wire up an engine, you can go to any craft store or radio shack, and buy what ever size/color of wire you're looking for, then get a pin vise to drill the holes for the spark plugs in the appropriate location and connect them all to the distributor.
2) I've heard a lot of different tapes being used including Magic Scotch tape, but anyways you may use any tape that you like, just make sure to test it on scrap plastic to see if it'll damage paint surfaces or bleed. But I would say it's best to invest you're money into Tamiya products for masking tape which can be purchased at Hobby Link Japan and other internet stores, and if you're lucky even a hobby store near you! Also, if you don't want to do the trim painting, you could always replicate the way Yenko did it (look at your sig, there's no chrome trim around the windows.)
3) Foiling, you can use a product from Bare Metal Foil, or even Testors for that one. Check out Scale Dreams for some.
Remember, there are no stupid question about modeling... everyone is at a different level and is still learning so don't be afraid, we won't bite! I think...
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 08-18-2003, 10:23 AM
tanner07's Avatar
Thanks for the help Honoturtle, I'm not sure what my plans are yet though. I was gonna lower the front but I am afraid of wrecking something so I don't think I will, probably just build it box stock. I want to make it red w/ white stripes with the front and rear spoiler and the grill with the 2 round headlights. 2 tone flat black/flat tan interior with some gloss black highlights maybe?
About wiring it..you said to pick up whatever size and color wiring I need...what size and color of wire should I use
Also, another question. When I paint the inside of the roof (ceiling I guess) of my Camaro, Is there a better way than masking off the whole car and spraying it? Thanks again
Old 08-18-2003, 10:36 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: First real model
1)Just see how big the motor is and and see what colors you think would go good in there and buy what you need.
2)Just mask off the windows and then the spray won't get out.
Hope that helps.
Old 08-18-2003, 10:50 AM
tanner07's Avatar
Re: Re: First real model
Hope that helps.
ah never thought of that thanks And if I'm not incorrect I should apply that paint in light coats, to help prevent bleeding then as soon as I have my last coat on I take off the tape? Or do I wait untill it's dry to take it off. Thanks....again
Old 08-18-2003, 10:59 AM
EMAXX's Avatar
Re: Re: Re: First real model
Yes, light coats and you take the tape off after about 5 mins, don't let it totally dry, becuase then the tape will be stuck, but you can't have it too wet either.
Old 08-18-2003, 11:06 AM
tanner07's Avatar
ok, thank you. And when I attach the wires to the distributor, how do I do it? Do I need to drill 8 tiny holes (one in each one of those things that sticks up)? And if anyone knows a picture that shows the correct firing order of a 1969 Camaro 302 (something like this, except this is for an Olds 442 http://www.oldsmobility.com/images/firingorder.gif) I would appreciate seeing that
Old 08-18-2003, 11:37 AM
EMAXX's Avatar
I wouldn't drill them. I have this little pokey tool thing. Its just like a screwdriver, but has a pointy tip. I just use those and poke little holes then just stick them in there.
For the pics, just look on google, there are tons there. I'm restoring this same model and I went there and found everything that I needed.
Old 08-18-2003, 11:57 AM
tanner07's Avatar
Alright, thanks for the help everyone I think that's about all the questions for now, but I will update now and then with progress if anyone's interested.
Old 08-18-2003, 11:58 AM
EMAXX's Avatar
Glad to be of help. Good luck with the model.
Old 08-18-2003, 12:09 PM
Here's a link for some reference for firing order: http://modeltech.tripod.com/wiring101.htm
You go under the first one for Chevrolet, but I'm assuming that you're using the 302 c.i.d. motor.
Also, you can always paint the interior roof by just using a brush.
AF MODELING FAQ
