Old 08-17-2003, 10:08 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
motor swap
k, heres the prob, i have a 90 civic with a 1.5 with a 4 speed n i want to do a motor n transmission swap to a b16 with a 5 speed trans, n i was wonderin if the mounts would match up or do i need customizing, also the axles for the trans i assume i have to change the hubs too cause of the splines? with the harness is that hard to switch in a civic for when i do the swap?
Old 08-17-2003, 11:04 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
You'll need to do some modding, including mounts, wiring, ECU, tranny, (engine of course), and axles. You should be able to keep your hubs. It's not too bad of a swap, but you'll want to do your homework first. Check out The Hybrid Pages they have some really good stuff, just look under the 4G tech section. The wiring isn't too easy, but they have diagrams for it there that will allow you to keep your original harness.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 08-17-2003, 11:09 PM
rex oner rex oner is offline
Send a message via AIM to rex oner
yah you need
mounts 200-500
b16 motor with cable trans. 800-1200
shift linkage - about 150
integra axels (2g) 50-300
some on to wire it -about 200-400
then you will run like a champ!
M T R LESS CRX!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
