Old 08-17-2003, 05:12 PM
xkornx07 xkornx07 is offline
Trans am engine swap
Alright, well myself being a mechanic, but still relatively new to swapping engines on cars anyways.. am looking for some advice. I'm looking to get a late 70's trans am and swap the engine. My primary choice would be to use a 505 cu in viper engine, however i'm aware that this might be more that a tight fit. What would my next best bet be, as well as what else would i need to be replacing here. It'll have a manual transmission too. Thanks guys!
Old 08-22-2003, 06:48 PM
V-8Fan V-8Fan is offline
Sounds to me like you are looking for performance!
To avoid all kinds of headaches, I would go with a small-block Chevy. You can certainly get gobs of performance out of one in a relatively economical way. If you really gotta have more, you can go with a big-block Chevy, but they are not as flexible and forgiving as a small-block (or cheap to build).
I suggest this because all you have to do is round up GM parts and they'll bolt right in, as far as just making things fit. Even if you could get the Chrysler engine to fit, and you may not, there would be no end to the fabrications required and the attendant headaches. Besides, it's really hard to beat a well-built 350 or one of its derivatives in terms of performance and reliability, and they're easy to set up.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
