Old 08-17-2003, 12:29 PM
crabby760 crabby760 is offline
referee smog check...
hey everyone i just bought a 93 civic dx coupe and it has a b16a japan engine in it not a b16a1 or b16a2 just B16A i have an appointment for a referee smog check next wensday i was curious if anyone knows if this motor will even be able to pass and be legal so i can drive it? they say that the referee is the one who will legalize the engine but i would just like any info on this please... the motor is bone stock right now also what precautions shoudl i do before taking it in there???? thanks
Old 08-17-2003, 01:30 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
2 cats, then when you get home, none
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 08-17-2003, 02:16 PM
what does that meen dude???? let me know and can someone please give me any info..thanks
Old 08-17-2003, 02:38 PM
michaelsd16c michaelsd16c is offline
Well I'v heard that if you change the Intake Manfiold with the EGR valve it will pass. The inatake has to be from a USDM b16a2 or b16a3 those two are from a 99-00 si / 94-97 Del Sol Dohc Vtec. Tell of it worked. Good luck!
Old 08-17-2003, 02:44 PM
so with just a all stock b16a jspec the referee wont make it legal so i can get my registratioN???
Old 08-17-2003, 02:55 PM
Look with a JDM motor It's not legal period. If you wanted the same motor then you should have gotton a USDM b16. Unless you can find another referee and pay his some extra $$$ mabey he might let u pass.
But other then that your......screwed.....sorry man
Old 08-17-2003, 03:00 PM
the car came with this engine man i didnt put it in the car... so basically there is no way i can get it smoged and passed so i can get registration on this car????
Old 08-17-2003, 04:15 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
As long as the cat is still there there should be no problem. As I've said before, myself and a bunch of my friends have JDM swaps and we all pass emissions. Cali restrictions are harsh though. Just take it to the test center to see where you're at. It doesn't cost much.
Old 08-17-2003, 04:26 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Also of note, you can't by law put an engine older than the car itself. For example, you couldn't put a '91 B16 (JDM or USDM motor) into a '93 vehicle. The engine must be the same year or NEWER for it to pass the visual inspection. The mechanical part is easy, it's the visual inspection that they screw you on and you may have to find a shady shop that you can pay them off to sign the papers. Like said above, if had gone with a USDM B16, you wouldn't have much to worry about...
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 08-17-2003, 04:49 PM
hey b16ej um what do you think about me going to the referee my motor is bone stock right now how did you guys pass smog? let me know thanks...
Old 08-17-2003, 05:14 PM
the motor is 94 all i need is the referee to sign me off and pass the smog test for me so i can go to the dmv and get my registration..... for the car under my own name....
Old 08-17-2003, 06:32 PM
I thought that the motor was a 93' that what it says on the other post?
Did you ask the orignal owner how he had it smog passed? Sorrry about the mix's up...You know the car came with the motor
Old 08-17-2003, 06:35 PM
yeah i know it came with the motor but i didnt know it wouldnt pass smog and he said he has taken it and its passed smog before he said as long as i could get it up on the tester it would pass smog but i took it to a test only shop and it didnt pass smog so they told me to go get a referee and see about them passing it and stuff .... please give me any info on stuff i should know...
Old 08-17-2003, 06:56 PM
Cali Guy
Re: referee smog check...
What part of the smog test did it not pass? The mechanical (pipe sniffer) test, or the visual inspection? If mechanical, what part specifically did it fail?
If it was the visual inspection it failed, most likely than not, a referee won't pass it then since they are more tightly governmentally regulated than a normal auto shop that does smog tests are. If you can't pass the visual, there is NO legal way for you to pass other than paying off some shady shop owner to write it off for you. Anyone in Cali that can't pass the visual will tell you that if they have mods or a JDM motor that is preventing them from passing legally.
hessemer69 on AIM
Old 08-17-2003, 07:25 PM
i failed the pov and nox tests..... the visual wasnt a problem except i didnt have the heat shield on the header.....
smog check for newer civics? smog check experts? bionictony '88 - '91 Civic | CRX | Wagon | Shuttlee 0 05-13-2006 03:42 AM
