Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-29-2001, 08:02 AM
lloyd_nickens's Avatar
lloyd_nickens lloyd_nickens is offline
Bluebird
Who would I call to get a used turbo for my G? I have plans on getting it blueprinted from Turbonetics b4 I put it in my baby. I'm shooting for 1 bar of boost through my engine. What else would I have to do to achieve that? Also what is the highest amount of boost I can attain without altering the compression ratio?
"God Bless BASS, What Would We Do Without It?"
"If You Can Breathe, Turn The Music Up."
Old 11-29-2001, 08:44 AM
APEXSER APEXSER is offline
Turbo Setup
What exactly are you trying to do with the car! You can't build a turbo system based on *boost*! 1 Bar on a T3/T04E is a lot more power than 1 bar on a T25; understand? Now if you said, " I want 200 whp" , then I would say get a used Bluebird setup, mount it on your DE and you will have that power with an intercooler and JWT ECU!
Louis Anaya
1992 Nissan Sentra SE-R Turbo
12.0 @ 118.77 mph
349.6 HP & 301.9 FT/LB
SR20 Performance
www.sr20performance.com
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 09:05 AM
I'm actually looking for about 250 whp (my slushbox will be "leveled up"). And the I was thinking about using the T25 because it is inexpensive. Although I plan on using a T3/04 Hybrid in a later setup.
Old 11-29-2001, 09:50 AM
250 HP w/ T25....
....No WAY! You will have to change up the manifold and turbo to hit 250 hp if you start off with the T25. Do yourself a favor and get the T3/T04E from the beginning! Another alternative would be to get a GTiR Manifold and T28! That will produce 250 whp with a Cobra MAF, MSD 50 lb/hr injectors and ~13-14 psi!
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 10:20 AM
Would fuel injectors from a 300zxtt fit because I know of one that I can get them from. If the T25 can't do it then I'll go with the T3/04 (I think). Besides where would I get a T28 and the accompaning manifold from. And the Cobra MAF can be picked up where and for about how much.
Old 11-29-2001, 11:04 AM
I don't mean to sound like a dick....But it sounds to me as if you haven't done any research. Research is very important when trying to turbocharge a vehicle! 370cc injectors can come from 91-96 300ZXTT, 94-96 Q45, 91-98 Bluebird, S13 & S14 SR20DET's! 370cc injectors will max out at about 230 hp! That is why Itold you you will need MSD 50 lb/hr injectors to reach your goals! The Cobra MAF can be purchased from JWT, Ford Dealerships, or other aftermarket Vendors such as APEX Motorsports(Shameless Plug) !
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 11:47 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
well, that's what he's doing right now...researching by asking questions here.
yes, the injectors from the Z32 will fit but u'll also need to get the fuel pump fromt he Z as well...you'll need to get that if you are aiming for 250hp. 370cc is good enough for 250hp, especially if you are gonna boost 1 bar.
to change to a different turbo such as the t3/04, u'll need to get a different manifold...if you wanna keep the same manifold (and if money isnt an issue) go for the HKS GT 25/30 ball bearing!! that'll do you good up to 300+ and it's ultra responsive. a TD05 will also fit on the facotry BB manifold too.
250hp isnt such a distant goal though if you are not planning to swap turbos and just use the factory t25. a 3inch exhaust, properly tuned ecu, the larger injectors, and if you boost 1 bar, should be no problem and wont max out the turbo.
Luke C.
GDA Power!
Old 11-29-2001, 12:44 PM
I've been reading post. I just got my G about a month ago so I am still getting used to it. I love it to death, and I am thinking about getting it hooked up. I already have a system in it. And now I am trying to move on to something that I am not as knowledgeable about. This car seems to be the perfect platform for creating a sleeper. So I'm hoping to be able to exhange information with you guys in hopes to further my knowledge of the whole car think. What do I have to offer? Car Audio knowledge.
Old 11-29-2001, 12:55 PM
I can not recall a single person who has dynoed 250 hp with a T25 or 370cc injectors. Anything past 10 psi on a T25 becomes very inefficient! The 370cc injectors max out at 230 hp! You would run *EXTREMELY* lean if you try and push those injectors past 10-12 psi with a T25. The factory MAF is maxed out right around there also! I am not sure where you are getting your information, but by stating that 250 whp is attainable with 370cc injectors on an SR20 is just plain ignorant! That would be a very costly mistake!
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 01:22 PM
what about the fuel pump?
Old 11-29-2001, 01:55 PM
Fuel Pump!
You can use a 300ZXTT pump, but the fitament isn't exactly the greatest! I would suggest a Walbro 255 lph pump! You can get them for about $150.00.
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 02:52 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Re: Fuel Pump!
Is that going to fit in a G20?
Old 11-29-2001, 04:02 PM
nwong nwong is offline
How does the G25/GT30 BB turbo compare with the T03/T04 turbo?
Old 11-29-2001, 04:13 PM
Re: Re: Fuel Pump!
Which of the 2 are you refering to? The 300ZXTT *SHOULD* fit all 91-93 G20's and Walbro makes pumps for both 91-93 G20's and 94-96 & 99-00 G20's.
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 11-29-2001, 04:46 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Re: Re: Fuel Pump!
Mike Kojima sent me an A32 or A33 fuel pump for me to install in the G. Now I just need some time to figure it all out. Time is something I'm short on at the moment and probably will be for some time. But, the A32 (or A33, whatever) should work fine as well with a little customization (like all other fuel pumps require).
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
