Old 08-17-2003, 02:49 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
R32 GT-R rebuild
some of you that have been around these parts for a while may remember the build up of this kit.
Finally after having the wheels sticking out of the arches glaring at me for so long I have finally decided to add some custom flared guards front and rear to add some form of realism to the kit.
Old 08-17-2003, 03:21 AM
tazdev's Avatar
I'm still here
parts were first sketched on paper then cut out and place on the shell to sort out how the styrene should be cut. This was then transfered onto the styrene and cut out. the sections will then be overlayed to form the basic shape for the flares before the addition and forming of the putty.
work is underway on the rear guards but as yet I am still undecided onto the correct look for the front guards.
am I going about this the correct way?
Old 08-17-2003, 03:26 AM
[ c e l s i o r ]'s Avatar
[ c e l s i o r ] [ c e l s i o r ] is offline
Send a message via ICQ to [ c e l s i o r ] Send a message via MSN to [ c e l s i o r ]
looking good to me
Professional Web & Graphic Design @ Minimal Rates, Unbeatable Prices. PM/E-Mail me.
Old 08-17-2003, 06:13 AM
flyonthewall's Avatar
Car Mod guy
Looks good! Can't tell what thickness plastic your using, but u could use .005 and stick 2-3 layers on eack arch and they will conform to the curves very easily.
Will you also taper the edges into the bodywork and maybe add some rivets?
Old 08-17-2003, 06:20 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Wow!
and I thought the GTR already had flared guards!
I can not think of a better way of doing it, Iv built a plane wing the same way, just layers of plastic sheet, and some putty.
But remember you can sand and file the plastic to form a curve as well, to minimise your putty useage.
And is it possible to get the basic shape of the guard on the car, useing the clips as you have, then take it off for final shaping, this way you can build both sides at once, and compare them side by side to make sure they are the same.
The front flare is going to be ticky though, if you make it a big one in the same style as the back then you have to work on the bumber as well as in coperating that panel crease.
How about something more simple, like a thin extension the same as the AE86 and Starlets get?
Old 08-17-2003, 06:54 AM
yellow15's Avatar
yellow15 yellow15 is offline
Sounds like real "fun" heeeee
i'm sure it will turn out awesome!! keep us updated
DRAW PHOTOGRAPHY
Old 08-17-2003, 10:01 AM
tonioseven's Avatar
Thumbs up
That one is an oldie but goodie! Looks like you're off to a great start so far!!
Old 08-17-2003, 10:04 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Looks good. Can't wait to see it done.
Old 08-17-2003, 10:10 AM
Looks great. What color will it be resprayed?
Old 08-17-2003, 03:24 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
Re: R32 GT-R rebuild
I'd love to see a black with a white or yellow stripe
Old 08-18-2003, 12:18 AM
tazdev's Avatar
I'm still here
haven't decised yet but I know for a fact that it will NOT be staying gunmetal grey
Old 08-18-2003, 01:27 AM
What about blue? J/K you just did one in blue.......
How about yellow, I remeber a pic in one of my magazines that had a yellow R32 GTR with the words "Legendary Snail" as a windsheild banner........ or make it black with some Nismo stickers would be cool as well!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 08-18-2003, 02:21 AM
tazdev's Avatar
I'm still here
Don't think that would flow properly with the rest of the kit. Looks like it will be a major on the front end
Old 08-18-2003, 02:30 AM
tazdev's Avatar
I'm still here
here is the rear still in its rough stage. Just trying to get things as even as possible.
here is a pic of the new rear beside a standard GTR rear just to give an idea of exactly how wide it is.
Old 08-18-2003, 05:31 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Great idea Taz. Can I suggest for the front just extend the guards slightly as if the car had a widebody kit on it. It looks like you did this with the rear instead of flaring the guards which is what I thought you were going to do. I have some pictures af an R34 with a Blitz widebody kit. Hope this helps.
