Old 08-16-2003, 11:20 PM
blade34609's Avatar
blade34609 blade34609 is offline
Ground points?
Hi,
Can one of u guys tell me where the ground points are on the D15 1.5 liter engine.
I know there is one on the valve cover to the chassi.
Also there is one on where the clutch cable goes right?
It comes from the negative battery cable?
My valve cover one to the chassi isnt on there really tight because i think it stripped the bolt.
If it isnt on there really thight and snug (u can move it with your hand back and forth)
could this cause the alternator not to charge and my check engine light go on?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 08-17-2003, 12:46 AM
BullShifter's Avatar
Bad grounds can cause problems with the electrical system. There is the valve cover to left front engine compartment & Battery to r. front inner fender to transmission. There are many other grounds on the car
Old 08-17-2003, 12:55 AM
blade34609's Avatar
Ok.
well the ground cable from the valve cover to front of chassis was stripperd (bolt was) so it wasnt puttin it down tight.
You could easily move it with your hand.
So I just took the ground wire and put it through the bolt that goes to the radiator hold down bracket.
It holds it down real tight and you cant move it anymore.
this should ground it good I hope.
The other one is on real tight right by the tranny and clutch cable bracket.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-17-2003, 01:03 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
dont forget the one on the wiring harness that goes near the thermostat
Team Lonely Drivers
Old 08-17-2003, 01:07 AM
blade34609's Avatar
Yup checked it and it is tight on the bolt on the thermostat.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-17-2003, 01:08 AM
also your getting a cel, whats the code ?
your alt could just be bad, take it down to your local parts store, they should be able to test whether the alt is good or not
Team Lonely Drivers
Old 08-17-2003, 01:16 AM
blade34609's Avatar
Brand new battery and alternator.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 08-17-2003, 01:30 AM
what code u getting ?
did u make sure all the alt wires are on good and on the connector good
Team Lonely Drivers
