Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-16-2003, 04:49 PM
Chase95gsr's Avatar
Chase95gsr Chase95gsr is offline
Send a message via AIM to Chase95gsr
Lightbulb Intalling an exuast system
Hey guys,
i just bought a tunabe exhaust and i was wondering is it worth it to get it installed professionally or is it easy enough to do it your self if you have the right tools. Also what tools would be nessesry to do it. thanx
Chase's 95 G-SR
Old 08-16-2003, 05:27 PM
BullShifter's Avatar
Some times its easy to remove old exhaust & other times its a bitch. Soak the bolts you need to remove over-night with penatrating oil. If rusted severly then an impact gun should be used. Otherwise you may be able to remove the bolts with a socket wrech & wrench. Swapping exhaust on jack stands can also be a challenge. Overall I feel changing exhaust is fairly simple if its a true bolt-on.
Old 08-16-2003, 06:11 PM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
Took me an hour to do mine.....no need to bring it to a shop..
2001 ITR
WWW.SQUADONE.NET
Old 08-17-2003, 06:13 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
yeah... you can do it!
only hard part will be the bolts on the cat.....
soak them like mad!!! and heat will help
ITR inside
Old 08-18-2003, 11:35 AM
Chase95gsr's Avatar
ok i keep hearing this soak the bolts but how do you soak something when its on the car and soak them with what.???
Chase's 95 G-SR
Old 08-18-2003, 01:39 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
its more like drench, not soak. DRENCH the bolts that connect the catalytic convertor to the rest of the exhaust system with WD-40 or another penetrating oil. only other bolts that you'll have to remove are the ones that connect a hangar to the exhaust system (between the cat and the resonator). might have to disconnect the section behind the rear axle as well...
Old 08-18-2003, 01:52 PM
J92GSR J92GSR is offline
I recently installed my tanabe exhaust, my bolts were rusted together, even with wd 40 it didnt come off i had to drill through it with 2 titanium bits and it took me a couple of hours but felt damn good to do it to yourself, but i doubt your bolts will be as rough as mine were.
Old 08-18-2003, 10:31 PM
WD-40 doesnt work to well on old ass exahust bolts. Try a better penatrating oil, I use a product called "Really Good Shit" I dont think they can sell that in the store How do you soak them? Spray the shit out of them a few times. First try tightening then remove the bolt. Just give a little turn to break it loose - then removing should be easier.
You drilled out the bolts
You just cut the damn things with a cut-off wheel on a drill, angle grinder, or cut-off tool. I dont think you wanna try with dremel too, that may take longer than drilling. Shit you could even snap the bolts with an impact or even enough force with a breaker bar. Then pound the rest out with a Ford wrench(hammer) Cutting torch is best!!!!!!!!!!
Old 08-18-2003, 11:21 PM
A_C_U_R_A-GSR-97 A_C_U_R_A-GSR-97 is offline
Re: Intalling an exuast system
Originally Posted by Chase95gsr
Hey guys,
http://www.deepstaged.net/installs.htm
If you drive slow, STAY DA FREAKIN' OUT MY LANE!!!
1997 ACURA Integra GS-R
3" PVC Intake
Test/Straight Pipe
***SOON***
AEM v2 CAI
Random Tech Hi-Flow Cat Converter
A'PEXi N1 Series CatBack Exhaust Sys
DC Sports 4-1 header
Old 08-19-2003, 07:45 PM
CryptzKilla CryptzKilla is offline
Heh...longest time I ever switched a cat was 6 1/2 hours. Anyone beat that =P?
Old 08-21-2003, 01:25 PM
Ls4Me7o7 Ls4Me7o7 is offline
Send a message via AIM to Ls4Me7o7 Send a message via Yahoo to Ls4Me7o7
took me 2 hours to do mine ...basic bolt ons are a SINCH
.:2nd Gen Integ LS (90')
-Aem Cold air
-Greddy SP Full cat
-Modified ECU
-DC 4-2-1 Headers
-Eibach Sportline Lowering Springs
-Tokico Blue Gas Shocks
-JDM 1 peice headlights
-Autometer 5" tach w/ shift light
-2 2-5/8 autometer guages (volts & oil press.)
-2- 12" Xplod woofers
-1000 watt Xplod amp
-Brown / Custom white interior
-Indiglo guages
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 07:32 PM
Announcement of TOYOTA(Guangzhou) on Camry's braking system defect ChinaCamryUser Camry/Camry Hybrid/Vista 3 04-27-2009 11:54 PM
CAN (controller area network) or FlexRay systems? rnelson3 Engineering/ Technical 0 04-24-2009 10:27 AM
exuast system edwardoh Camaro Discussions 0 06-28-2004 02:04 PM
Exuast Systems???? FLYIN Z Nissan 350Z/370Z | Infiniti G35/G37 Coupe 1 01-06-2003 12:40 PM
