Old 08-16-2003, 04:25 PM
mtx410 mtx410 is offline
Send a message via ICQ to mtx410 Send a message via AIM to mtx410 Send a message via MSN to mtx410 Send a message via Yahoo to mtx410
Question A/C temp flashing!! it IS fully charged?!?
i've got a '94 buick lesabre limited with climate control. i evacuated the a/c system and recharged it to where it was supposed to be. now when i start the car up it blows out hot air for a few seconds. then the temperature on the climate control starts flashing and it gets cold as soon as it starts flashing. then it works fine until i shut the car off again. a friend of mine has a '94 park avenue and it's doing the exact same thing. is there just something that needs to be reset? if so what is it! please help!!
Old 08-16-2003, 08:46 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
If the lights are flashing then you have a problem. It could be a under charge or over charge causing the lights to flash. You can try disconnecting the battery to erase the codes stored and see what happens. Most likely the codes will come back.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 09-17-2003, 03:44 PM
mickel1138's Avatar
mickel1138 mickel1138 is offline
Send a message via AIM to mickel1138 Send a message via Yahoo to mickel1138
I have a 1993 LeSabre with the same problem.
I remember reading somewhere this has to do with under or over pressure. Tho my pressure is fine, and I even replaced the cycling switch. It also said that the AC control unit has to be reset, something that can only be done by a certified mechanic? With what? I don't know.
Maybe there is a way to reset it? I went to 2 certified mechanics, both said the unit simply had to be replaced. Now i'm looking for a unit on eBay or junkyards unless someone tells me how to reset the unit.
Just FYI, hope it helps...
Mickel
Old 11-05-2003, 08:26 AM
ghink ghink is offline
I have the same problem on my 1994.
Did you ever solve the flashing problem?
Old 11-05-2003, 05:02 PM
mickel1138's Avatar
Re: A/C temp flashing!! it IS fully charged?!?
I have since sold the car, and I still believe reseting or replacing the AC controller will fix it.
I found a service bulletin from GM 93-1-1, Nov. 1992:
A/C System Switches to ECON Mode and compressor inop.
Code 48 in A/C system, SCAN tool interface problem.
It basically says a scantool or some kind of key was inserted into the DCL. And caused the system to think there was something wrong with the A/C.
A code 48 will be set in the A/C controller itself, and can be reset trough "onboard diagnostics"...
Simply resesting the ECM (disconnecting battery) will not work!
Don't ask me how to reset the A/C controller, I removed it, examined it, but the problem persisted.
I have the service bulletin available if neccesary.
Let me know if you solved you problem.
Mickel
fully charged battery dies within 8 hours Jim_McQueen General Discussion 8 09-17-2004 10:59 PM
