Old 08-15-2003, 05:15 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
ac troubleshooting
Alright...the ac clutch does not ingage so I went through the troubleshooting steps...i have voltage on the white wire and the blk/yel so next it tells me to put a jumper from white to red which works the clutch ingages...now it says to disconnect red terminal and check voltage on it which there is none so now it says to fix open in red wire between compressor clutch relay and compressor clutch connector...this doesnt make sense...if there was an open in the red wire how did jumping the red and white make the clutch ingage...does that make sense...someone help me out here
Honda...An Army Of One
Old 08-30-2003, 12:30 AM
tru2037 tru2037 is offline
Send a message via AIM to tru2037 Send a message via Yahoo to tru2037
a/c problems
a/c is simple. All a/c systems are about the same. power comes froms your control panel to a sensor called a freeze switch to a high pressure switch to your compressor. It may have a relay in here, my honda dosent have a/c just going on knowledge. THe relay should have a constant wire, ground, hot from control panel, and a wire going to the a/c compressor. If you jump your freeze switch, which it sounds what your doing when the clutch activates, you just need freon.
[email protected]
1995 325i Cooling system overheating troubleshooting kennethwperry 3 Series 0 09-20-2009 07:32 PM
Car Won't Start: Troubleshoot ivymike1031 Engineering/ Technical 0 09-05-2002 10:08 AM
Airbrushing tips - and troubleshooting MercCougarXR7 Car Modeling 6 12-01-2001 09:45 PM
Beer Troubleshooting YogsVR4 COMPLETELY off-topic 5 08-22-2001 06:16 PM
