Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-15-2003, 12:43 PM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
Unhappy help
i am the proud owner of a 1980 toyota celica gt Convertable does any onw know of performance parts for the engine, it has the 20r, and i am also looking for a reson why i only have two gears with the 5 speed, it still shifts fine, but dosent engage into any gear other than 1st and reverse, also, does any one know where to get this top reskined?
Old 08-15-2003, 01:08 PM
Antyoo Antyoo is offline
Re: help
sounds like you have a busted tranny
Old 08-15-2003, 02:21 PM
killasoundz killasoundz is offline
there are tons of places to get parts for your 20R. check out www.lcengineering.com they have all kinds of great stuff including fully built engines, turbo kits, cams etc. the 20R and 22R respond excellent to mods. the parts i have installed on my car right now include. a stock 20R bottem end, lc engineering stage 2 (offroad)cam, 22R aluminum rockers, hedman headers, 2 1/4 inch exhaust all the way through, and an edlebrock 1408 series 4 barrel carb with lc engineering 4 barrel manifold. im guessing my car is putting out between 115-130 hp which is a huge improvement on the stock 76hp. all the parts installed on my car right now only cost me about $480. i bought the cam used and the rockers were free.
what i have in my garage being built will really kick ass and my goal is 250hp to the wheels and 350hp+ on race gas.
its an early model 22R block from an 81 celica, with a ported and polished 20R head, 48mm intake and 40mm exhaust valves, the same cam i have now will be put in, will use lc Engineering pro camshaft kit, LC pro rocker shafts, custom made aluminun roller rockers, knife-egded 22R crank, LC pro rods, LC low compression pistons, holly 2000cfm 4 barrel throttle body, LC 4 barrel intake, custom turbo manifold, garret ball bearing turbo, sds engine managment, ARP studs, Pertronix second strike ignition, LC pro distributor. ACCEL spark plug wires, bosch wideband O2 sensor, overdrive pullys, adjustable cam gear. etc.
so far ive only got the head done and the turbo plumbing but ive already put about $2500 into it for all the head work valves valve seats camshaft kit etc.
another great engine for these cars is the 18RG. DOHC 8000RPM redline. they make about 130hp stock depending on which version you get and come stock with dual mikuni carbs. e-mail this guy TIm at Tims toys. he'll hook you up with all the rare japan engines 18RGs will run you about $1000 in good running condition but are well worht it. [email protected]
also check out www.classic-celica.com and www.185performance.com for all your suspension needs.
1979 celica GT 5speed
help me help me help me please fuel pump help my90horsy Mustang Talk 16 12-05-2003 09:38 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Help Help Help Help Help lewdaka03 Jetta/Vento/Bora 1 06-02-2003 01:57 PM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
