Old 08-15-2003, 12:30 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
taking off rotors and calipers etc.
ok ive asked this before but never got a good answer, im taking 95 teg rotors off to put on my 91 hatch, ok so i was told to take off rotors calipers, not the hubs? is that right? and also is the steering knuckle the fat arm that extends up or the smaller one that extends to the side towards the axel? or not either of those???
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 08-16-2003, 07:40 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: taking off rotors and calipers etc.
Well if you're doin the conversion you need to change the whole thing.
Old 08-16-2003, 07:44 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
Re: Re: taking off rotors and calipers etc.
idk if the 95 front suspension will fit, but since you have everything, it would be best to take every piece and try to bolt it up your hatch.
you might have to use your upper control arm but take everythin else from the integra. tie rods/lca/front knuckles etc...
Julian
Old 08-16-2003, 08:42 AM
91civicDXdude's Avatar
Re: Re: Re: taking off rotors and calipers etc.
My brother swapped 91 Teg front suspension onto his 91 STD Hatch, all that is needed is the steering knuckles, also called "spindles". Use your stock suspension for the rest. (LCA, tie rod, etc.)
Scratch-build rotors and calipers jdmaccordian Car Modeling 1 12-12-2005 10:07 AM
replacing rotors and calipers krc333 4Runner/GX470 0 01-28-2005 03:19 PM
300zx rotors and calipers turbomaxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-13-2004 05:00 AM
Rotors and Calipers :S Civic Jim '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-18-2003 05:48 AM
