Old 08-14-2003, 09:59 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
Question Port Size: Please help
Ok, my box contains two Rockford Fosgate Punch Z's that are 10 inches, on the back it says 1.5" voice coil and 400 watt peak, so I assumed that it was 200 rms but some sites say only 150 rms but that's ok. I have a box that is made out of 3/4 inch thick board, and is 12.5" high in back, 7.5"deep on bottom, 5.5"deep on top, and the face is 12.85 inches tall. So the insides measure 11" x 6.00" x 4.75" x 11.35" x 16.375", which equals about 2.8 cubic feet per section because the box is seperated on the inside in the middle, I drew a picture, I hope it works for you, but I want to know how big I should make those primary ports, I put the board down about an inch because I dont want stuff falling from the top, I'll do it no matter what but I might put screen over the top port, I figured like 2" x 4"But I'm sure that I did the math right so each box is 2.8 cu. ft.
Then, I forget the name of the kid on here, he's the 15 year old one or w/e, I'm typing this on a word processor becasue AF is down at the moment, but in his sig he has like, "Just a 15 yr old kid wasting his money on car audio", so here for you is a list of amps, I dont want anything special, just something that is pretty cheap and will work for now until I get a better one or a different vehicle, so if you can, look at all those amps and tell me what would be the best, I dont want to spend much, I only spend 100 bucks for both of those subs and a box but I have to resize the box. The help would be great, thanks!!!
Btw, I've never looked into it, but what's the advantage of MOSFET?
http://www.millionbuy.com/bosk580.html
http://www.millionbuy.com/jenjxp720.html
http://www.millionbuy.com/prfca800.html
http://www.millionbuy.com/prfcl800.html
http://att.dealtime.com/xPF-Power_Ac...Gothic_OV2_820
http://store.yahoo.com/millionbuy/kenkfcc6889.html -Door speakers I think I want, any good??
http://www.millionbuy.com/bosk680.html
http://www.millionbuy.com/prfca1200.html
http://att.dealtime.com/xPO-Power_Ac...othic_OV2_1200
http://att.dealtime.com/xPO-Lanzar_Vibe_250
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 08-15-2003, 09:38 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Port Size: Please help
I am not quite sure what ohm rating your sub is but here, look at this http://cgi.ebay.com/ws/eBayISAPI.dll...category=18797
Old 08-15-2003, 08:52 PM
v10_viper's Avatar
Re: Re: Port Size: Please help
Yeah it'd work for one sub, but I have two of them, each 150 rms, and they are 4 ohms, but thanks anyways for taking the time, I really dont need a decent amp as this is just something that will work, also, should I just make it a sealed box?? A kid recommended it and he knows a lot of shit about car audio, has a truck like mine and one Kicker 10" CVR or something like that that is 300 rms, it's awesome in his truck.
Old 08-15-2003, 10:28 PM
Haibane's Avatar
Re: Re: Re: Port Size: Please help
I am just wondering, but why do you not think that a 2 ohm load at 320 watts would work fine for 2 speakers... It seems you do not realize that Class D mono amps are highly used for more than one subwoofers. Subwooofers do not do anything different in stereo, since bass is all in one signal. you just run 2 wires to one channel at a parrallel wiring.
If these are 4 ohm SVC then that is a perfect match amplifier that I gave you giving 320 watts rms at 2ohms to 2 subwoofers.
Old 08-15-2003, 11:06 PM
v10_viper's Avatar
Re: Re: Re: Re: Port Size: Please help
Yeah I see your point, I have considered all of what you just said in that post, but the reason I'd like to have two channels is because some songs that I listen to are different from left to right, one song by Nelly has it where it does a thing on the left, then right, then repeats that, and I think I'd like it to be seperate channels, because this box is 35" wide and the subs are seperated quite a bit. It's not that I dont like your suggestion, I like the idea very much and I might end up doing it, I guess it's just personal preference, but I'll definately be thinking about it. Thing is, I'm not working to have a necessarily loud truck or anything, I just want it to sound good I guess. I mean it's the first time I'll have subs in a vehicle, so I'm not really worried about having it be an awesome one or anything, just something that thumps.
Old 08-16-2003, 07:16 AM
Haibane's Avatar
Re: Re: Re: Re: Re: Port Size: Please help
I am pretty sure that, setting up a set of subwoofers stereo will not change on that song, are you sure it is bass that goes left right?
Old 08-16-2003, 10:50 AM
v10_viper's Avatar
Re: Re: Re: Re: Re: Re: Port Size: Please help
Well if you say I should go with a mono amp over a 2 channel amp then I suppose I will, but I think it still want the load at 4 ohms don't I?
Can anyone answer my other questions in the first post??
Old 08-18-2003, 07:33 PM
Haibane's Avatar
If they are SVC and you have 2 of them 2 ohms is about your only bet, there is nothing wrong with running speakers at 2 ohms, most people have DVCs that run at 1 ohm, let alone 2 ohms, since you have 2 you and they are svc, you will want to wire both pluses from the speakers to the 1 plus on the amp and both negatives on the speakers to the one negative on the amp, if you choose to use 2 ohms, there is no downfalls in using a lower ohm power aside from more battery pull that I know of.
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please help! problem connecting to obd2 port on 1995 cavalier brandonppr Cavalier Problem Diagnosis 7 01-18-2008 02:16 AM
Port and Polish, please help MaximusGTR Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 12 12-19-2002 06:29 PM
